Add leader with rubber band, insert text
NachitoMax
NachitoMax
Hi
I'm looking to achieve a way of pasting text into a leader while being able to position it natively in a drawing sheet. What I mean by that is something similar to the following:
Select text from form
Text gets copied to clipboard
Leader command starts
Click start point, text position point
Text is entered / pasted into text window
Or put another way
Select text I want on my sheet from a form
Position the leader on the form
Text is entered into leader
I can currently do this but I cant pre position the leader points or show the leader attached to the mouse pointer.
Any way of of doing this?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (0)
