Add iAssembly through iLogic Rule
I am trying to add an iAssembly through an iLogic Rule.
This the code I am using.
Components.AddiPart(xyz:1, xyz.iam, {"Member", "A"})
However, on running the rule, it says :
File "d:\foldername\xyz.iam" does not exist or is not an iPart factory.
(The name of the actual file and path has been changed for this post)
But I am 100% sure that this is an iAssembly.
Does iAssembly not work with "Components.AddiPart" function?
Daan_M
The snippet is placed under the 'iLogic Assemblies/Components' tab, but i don't believe it is meant for adding a complete iAssembly into a document when i read the description.
Maybe the code 'Component.Replace' helps
J-Camper
This is how it has worked for me in the past, where oPos is a Matrix and SelectRow is an Integer:
Dim NewoOcc As ComponentOccurrence = ThisDoc.Document.ComponentDefinition.Occurrences.AddiAssemblyMember(FilePath, oPos, SelectRow)
I have had luck changing rows of an existing iAssembly with shorthand, where Row is an Integer:
iPart.ChangeRow(oOcc.Name, Row)
dutt.thakar
@Anonymous
Component.AddiPart does not work for iAssemblies.
What you can do is use these snippets instead
Components.Add("xyz:1","xyz.iam") - To add the iAssembly inside your assembly
iPart.FindRow("xyz:1","Member","=","A") - To change the row that you want to in that iAssembly.
Please accept this if this has answered your question.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Thanks @Daan_M  and @J-Camper for your replies.
@dutt.thakar your solution works.
Thanks again
