Add folder browser when exporting .step using ilogic
m.rymut
m.rymut
I have an iLogic rule that lets me export selected parts from assembly as step files.
I want to add a modification so that when i select parts and run the rule, then a folder browser pops up and lets me choose where i want to save selected parts. Now it just saves step files in the same directory that the part files are located, but i want to be able to choose where i want to save .step files.
Rule i use for exporting selected files is from this forum, posted by  marcin_otręba.
The rule:
Public Sub Main()
'MsgBox("BOM QTY Update ")
Dim ass As AssemblyDocument= ThisApplication.ActiveDocument
Dim oselset As SelectSet = ass.SelectSet
Dim i As Integer = 0
Dim result As Boolean
Dim occ As ComponentOccurrence
If oselset.Count<>0 Then
For Each occ In oselset
Dim doc As Document = occ.Definition.Document
' Update or create the custom iProperty.
result=ExportToSTEP(doc)
If result = True Then
	i = i + 1
End If
Next
MessageBox.Show(i & " files successfully exported", "result")
Else MessageBox.Show("You must select files to export before running rule", "Error") End If End Sub 'Here's the subroutine. Function ExportToSTEP(doc As Document) As Boolean ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") If oSTEPTranslator Is Nothing Then MsgBox("Could not access STEP translator.") ExportToSTEP=False Exit Function End If Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oSTEPTranslator.HasSaveCopyAsOptions(doc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" oContext.Type = kFileBrowseIOMechanism Dim oData As DataMedium oData = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = Replace(Replace(doc.fullfilename,".ipt",""),".iam","") & ".stp" Call oSTEPTranslator.SaveCopyAs(doc, oContext, oOptions, oData) ExportToSTEP=True End If End Function
petr.meduna
Try this:
Public Sub Main()
	Dim ass As AssemblyDocument = ThisApplication.ActiveDocument
	Dim RutaExport As String = ThisDoc.Path
	Dim Dialog = New FolderBrowserDialog()
	Dialog.SelectedPath = RutaExport
	Dialog.ShowNewFolderButton = True
	Dialog.Description = "Choose directory for saved .stp files"
	Dialog.ShowDialog()
	If DialogResult.OK Then
		oPath = Dialog.SelectedPath & "\"
	Else
		Return
	End If
	If oselset.Count <> 0 Then
			result = ExportToSTEP(doc, oPath)
				i = i + 1
			End If
		Next
	Else
	End If
End Sub
Function ExportToSTEP(doc As Document, sPath As String) As Boolean
	Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
		Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
		uPath = Left(doc.FullDocumentName, InStrRev(doc.FullDocumentName, "\") -1)
		uName = Mid(doc.FullDocumentName, Len(uPath) + 2, Len(doc.FullDocumentName) -Len(uPath) -5)
		oData.FileName = sPath & uName & ".stp"
		ExportToSTEP = True
	End If
End Function
WCrihfield
This is just another version that I was working on for you at the same time.  It just puts the code for the folder dialog out into a separate function to keep the main code cleaner.
Sub Main()
	Dim oSelSet As SelectSet = ass.SelectSet
	If oSelSet.Count = 0 Then
		Exit Sub
	End If
	'this runs the custom Function defined below to return a selected folder path
	oFolder = GetFolder
	'make sure a folder was selected, if not exit rule
	If String.IsNullOrEmpty(oFolder) Then Exit Sub
	Dim Occ As ComponentOccurrence
	For Each Occ In oSelSet
		Dim OccDoc As Document = Occ.Definition.Document
		'get file name (without path & without file extension)
		oName = System.IO.Path.GetFileNameWithoutExtension(OccDoc.FullFileName)
		'put new STEP file name together
		oNewName = oFolder & "\" & oName & ".stp"
		result = ExportToSTEP(OccDoc, oNewName)
			i = i + 1
		End If
	Next
End Sub
Function ExportToSTEP(doc As Document, NewFileName As String) As Boolean
		ExportToSTEP = False
		Exit Function
	End If
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oData.FileName = NewFileName
		ExportToSTEP = True
    End If
End Function
Function GetFolder() As String
	'Imports System.Windows.Forms
	Dim oSFolder As String
	Dim oFDialog As New System.Windows.Forms.FolderBrowserDialog
	oFDialog.Description = "SELECT DIRECTORY TO SAVE STEP FILES IN."
	oFDialog.RootFolder = System.Environment.SpecialFolder.MyComputer
	Dim oResult As DialogResult = oFDialog.ShowDialog()
	If oResult = DialogResult.OK Then
		oSFolder = oFDialog.SelectedPath
	Else
		Return String.Empty
	End If
	Return oSFolder
End Function
Wesley Crihfield
(Not an Autodesk Employee)
m.rymut
Works perfectly, thank you very much.
m.rymut
Yes, i think i might have sent you a private message for help :grinning_face_with_sweat:
Code works perfectly, thanks for the help
