Add button too externales rules
JMGunnar
JMGunnar
Create Button for externales rules
how too access defintions too externales rules
Sub Main()
	AddPanelToToolsTab()
End Sub
Sub AddPanelToToolsTab()
    ' Get the ribbon associated with the part document
    Dim oPartRibbon As Ribbon
    oPartRibbon = ThisApplication.UserInterfaceManager.Ribbons.Item("Part")
    ' Get the "Tools" tab
    Dim oTab As RibbonTab
     oTab = oPartRibbon.RibbonTabs.Item("id_TabTools")
	 For Each item As RibbonPanel In oTab.RibbonPanels
		If item.DisplayName = "Update"
			oTab.RibbonPanels.Item(item.InternalName).Delete
		End If
	 Next
    ' Create a panel named "Update", positioned after the "Measure" panel in the Tools tab.
    Dim oPanel As RibbonPanel
    oPanel = oTab.RibbonPanels.Add("Update", "ToolsTabUpdatePanel", "SampleClientId", "id_PanelP_ToolsMeasure")
    ' Get the update commands
    Dim oDef1 As ButtonDefinition
    oDef1 = ThisApplication.CommandManager.ControlDefinitions.Item("AppLocalUpdateCmd")
    Dim oDef2 As ButtonDefinition
     oDef2 = ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd")
    Dim oDefs As ObjectCollection
    oDefs = ThisApplication.TransientObjects.CreateObjectCollection
    oDefs.Add(oDef1)
    oDefs.Add(oDef2)
    ' Create a split button control
    Call oPanel.CommandControls.AddSplitButton(oDef1, oDefs, True)
    ' Get the rebuild command
    Dim oDef3 As ButtonDefinition
    oDef3 = ThisApplication.CommandManager.ControlDefinitions.Item("AppRebuildAllWrapperCmd")
    ' Create a button control
    Call oPanel.CommandControls.AddButton(oDef3, True)
End Sub
WCrihfield
Which version of Inventor are you using?  If 2024, then when iterating through the ControlDefinitions, you will see some with the name starts with "iLogic.Rule:", followed by the name of the external rule file, and file extension.  That is the name of the ControlDefinition that the button will execute when clicked.  And if adding the rule as a button using an iLogic rule, it may only stay there for the current session of Inventor, then it will be gone again.  If you want the buttons to stay, you will want to add them manually, or use an add-in which puts them in place when Inventor starts.  And I usually just get the ClientID of he iLogic ApplicationAddIn to use there, instead of "SampleClientID", when it is just for iLogic related stuff.
Wesley Crihfield
(Not an Autodesk Employee)
JMGunnar
Thanks @WCrihfield
