Adaptive cut feature (sheet metal part)
knguyen_
knguyen_
I have a simple table including sheet metal parts & frame generator. When I change table width, cut feature of the top sheet metal does not change according to the width, but the bottom sheet metal does
robertast
@knguyen_
Adaptive sketch does not work well, it loses geometry and definition. This can be done by copying the object, it works more stable. And set the gaboites of your tabletop through the parameters and not through the designed sketch, otherwise your next question will be why the size does not change.
Watch the video
