ActiveCommand
ActiveCommand
Rene_Gerlach
ActiveCommand
Rene_Gerlach
How to get the ActiveCommand from my CommandControl Execute, or why is this not set?
Background:
I've more commands added to Inventor.
Also I attached to some Inventor Events.
The problem (or missing internal Inventor functionality) is that the CommandManager.ActiveCommand will not be set.
Also the NameValueMap didn't have this information.
Of course I can set my own internal variable to the Command, but all other Addins / Inventor self didn't known this...
Or did I something missing?
Cheers
René
PS: Sorry posted this first in General, if possible you can delete this there.
BrandonBG
CommandManager.ActiveCommand gets a string of characters that is the name of the command. By nature, this will only have a value while the ControlDefinition is running.
Can you give specific command that is giving you a problem?
Brandon
Rene_Gerlach
indeed what you tell is what I expected.
Samples which are not working are Tube&Pipe or my own command.
There are some more..
Cheers
René
adam.nagy
Autodesk Support
Autodesk Support
Hi Rene,
I could reproduce the behaviour and logged it in our system: #112949
So it seems that the Tube & Pipe commands do not set the name for the interaction - more info here:
http://adndevblog.typepad.com/manufacturing/2015/12/onactivatecommand-not-firing-for-my-command.html
Cheers,
Adam Nagy
Autodesk Platform Services
