accessing title block text fields
how can I access text fields of a title block?
for example I have 10 sheets and I need to type Eng.Khalid in the Subject text field in all the title blocks for all the sheets...
is there a code that can do this?
thanks in advance
any ideas?
1. Create a custom iProperty.
2. Create a custom property field in the title block.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
sorry but could you put more details, please?
The text in a title block can be defined in a few ways; it can be static
text as defined by the title block definition, it can be set to always
display the current value of a certain iProperty, or it can be a prompted
entry where the user is prompted for the value when the title block is first
created. Which of these are you using? All of them are accessible and
editable through the API.
Brian Ekins
Autodesk Inventor API Product Designer
http://blogs.autodesk.com/modthemachine
