Access "Driving Rule" info from parameters table via .net?
Hi everyone,
is it possible to access the information in the "Driving Rule" column from the parameters table via .net (vb.net)?
I have access to all of those information I need (comment, name, value, unit, expression list elements etc.) but I don't know the element to access the driving rule column...
Is there a way, to?
Greetings
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Unfortunately, Inventor API does not support to access "Driving Rule" of a Parameter.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
