access iproperties of "justSelectedEntities"
I use following sub to detect that a ipt in my Iassembly has been clicked.
if thre is only one selected, i would like to print the part number in a textbox. But I am not able to figure out how to get that information form the "justselectedentities" parameter.
 Private Sub m_userinputevent_OnSelect(JustSelectedEntities As ObjectsEnumerator, ByRef MoreSelectedEntities As ObjectCollection, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As View) Handles m_userinputevent.OnSelect
            If JustSelectedEntities.Count = 1 Then
                oForm.Auswahl.Visible = True
                oForm.TextBox2.Text = ************** PART NUMBER HERE *************
            Else
                oForm.Auswahl.Visible = False
            End If
        End Sub
could somebody please help me out on this?
Thanks best regards
Replies (10)
marcin_otręba
Try:
dim occ as ComponentOccurrence
 If TypeOf JustSelectedEntities.Item(1) Is ComponentOccurrence Then
set occ = JustSelectedEntities.Item(1)
end if
oForm.TextBox2.Text= occ.name
or
oForm.TextBox2.Text= occ.definition.document.propertysets.item(3).item("Part Number").value
Thanks, that works... i have a strange problem now tough...
i try to write some iproperties to my labels in the form.. this is the code:
                For Each objEntity As Object In JustSelectedEntities
                    If TypeOf objEntity Is ComponentOccurrence Then
                        'Do whatever you need
                        Dim cmp As ComponentOccurrence = objEntity
                        oForm.AW_Bauteilnummer.Text = cmp.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
                        Try
                            oForm.AW_ERP_Nummer.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("ERP_Nummer").Value
                        Catch
                            oForm.AW_ERP_Nummer.Text = ""
                        End Try
                        oForm.AW_Beschreibung.Text = cmp.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value
                        Try
                            oForm.AW_Nachbearbeitung.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("tan_Nachbearbeitung").Value
                        Catch
                            oForm.AW_Nachbearbeitung.Text = ""
                        End Try
                        Try
                            oForm.AW_Biegeteil.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("tan_Biegeteil").Value
                        Catch
                            oForm.AW_Biegeteil.Text = ""
                        End Try
                        Try
                            oForm.AW_Schweißbaugruppe.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("wec_Schweißbaugruppe").Value
                        Catch
                            oForm.AW_Schweißbaugruppe.Text = ""
                        End Try
                    End If
                Next
            Else
            End If
Try catch is used since older files dont have these custom properties.
The properties do exist in the file:
but if i click the IPT in my assembly only a few of the fields get filled in. why?
Moreover, if I edit the "biegeteil" value to "True", it still reads false, until i close and reopen the file.. no matter if I un select and reselect it.. is there a way to force it to re load the file with current data?
All i want to do is display those values of the selected file.
Thank you
marcin_otręba
Delete For...Next loop it's useless because your code works only if selected obj cout = 1.
Move oForm.Auswahl.Visible = True to the end of If... statement, in the end of filing text boxes.
Give me know if it helped...
unfortunately it didnt solve the problem.
tried to catch the exception, and for those that dont work it throws this:
System.Runtime.InteropServices.COMException (0x80004005): Unbekannter Fehler (Ausnahme von HRESULT: 0x80004005 (E_FAIL))
bei System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
bei Inventor.PropertySet.get_Item(Object Index)
bei TanzerFileProp.TanzerFileProp.StandardAddInServer.m_userinputevent_OnSelect(ObjectsEnumerator JustSelectedEntities, ObjectCollection& MoreSelectedEntities, SelectionDeviceEnum SelectionDevice, Point ModelPosition, Point2d ViewPosition, View View) in C:\Users\cad-13\source\repos\TanzerFileProp\TanzerFileProp\StandardAddInServer.vb:Zeile 215.
marcin_otręba
which line is 215 ?
marcin_otręba
in code is :
tan_Nachbearbeitung
in screen you have:
tan_Nachberbeitung
i dont see:
oForm.AW_Schweißbaugruppe.Text = odoc.PropertySets.Item("Inventor User Defined Properties").Item("wec_Schweißbaugruppe").Value
i checked the exception of only this row. but it will throw the same on the other on etoo..
Found it.. there is a typo in the iproperties... gonna talk to the admin here. :grinning_face_with_smiling_eyes: thank you!!!
now there still is the problem that if I eidt the data it displays the wrong data until i close and reopen the file.
marcin_otręba
did you moved
to the end of filling text boxes ?
And checked it after noticing wrong iprops ?
i think it should work if you unselect and select (because your code runs on onselect event) it again if you don't have any errors,
one more thing... i use on error resume next instead of try catch, you only must be careful when using if statements...
works! thank you very muchhhhh!! :))
