Okay, try this then:
Sub Main
'Verify rule is running in a part file. Not necessary, if stored local to Part File
If ThisDoc.Document.DocumentType <> kPartDocumentObject
Exit Sub
End If
'Declare main variables
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCD As PartComponentDefinition = oDoc.ComponentDefinition
Dim BrowserPane As BrowserPane = oDoc.BrowserPanes.Item("Model")
Dim oName As String
'Determine subtype of Part Document to know correct Browser GUID
'Sheet metal: "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
'Part: "{4D29B490-49B2-11D0-93C3-7E0706000000}"
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" 'Sheet Metal Part
For Each oNodeA As BrowserNode In BrowserPane.TopNode.BrowserNodes(1).BrowserNodes(3).BrowserNodes
For Each oNodeB As BrowserNode In oNodeA.BrowserNodes
If InStr(oNodeB.BrowserNodeDefinition.Label, "Pattern of") <> 0 Then
oName = oNodeB.BrowserNodeDefinition.Label
oName = Right(oName, Len(oName) -11)
oName = oName.Remove(oName.IndexOf(":"))
MessageBox.Show("Parent solid name for " & oNodeA.BrowserNodeDefinition.Label & " is: " & oName, "Parent Solid Found")
End If
Next
Next
Else 'Assumed to be normal part because earlier test
For Each oNodeA As BrowserNode In BrowserPane.TopNode.BrowserNodes(2).BrowserNodes
End If
Next
Next
End If
End Sub
It's a truncated piece of Pattern solid renaming code I used as an external rule, so some terminology may need to be added to get it to function as a VBA macro. It looks at solid bodies through the Browser Pane to determine their source body created from any kind of Pattern, and then renamed the solid based on the Parent name. If you would like the renaming portion I can post more but it looks like you have renaming done already. "oName" will be the name of your parent solid and you can set a SurfaceBody Object by checking for that name in "SurfaceBodies" if you need the parent as a SurfaceBody Object
