Hi all,
I have an iLogic rule, which basically contains the following;
Sub Main
'Do some checks and determine some values based on the document
Sub_1(.....)
End Main
Sub_1(.....)
While
Result_1 = Function_1(....)
Result_2 = Function_2(Result_1)
Total_Result = Total_Result + Result_2
End While
'Write Total result as txt file
End Sub
Function_1(....)
For each occurence
If occurence = phantom
'Repeat function 1 for sub occurences
Else If
List_1.add(...)
Else
List_2.add(...)
End if
Next
Sort lists and write to string, with ; between the values
Sub_2(...)
Result Function_1 = String
End Function
Function_2(...)
Split string based on the ;
Write back to arrays
Sort array lists
Write to custom table
Result Function_2 = string
End Function
I want the Arraylist be available (adding / get values) in multiple functions / subs, because now I have to write it to a string and split that string again in another sub. Is this possible? Also because I want to loop through the function and start it within each own, and I want all these results add in the same ArrayList.
I learned ilogic by meself using this forum and some basic coding knowledge, but I can't find an solution for this.
Is there someone who knows how to do this? (I would also be happy with an string which can be changed everywhere, than i stick to the splitting.)
