About the camera when finishing a sketch
When a user finishes a sketch the camera moves to a location that, most of the time, is troublesome and must be adjusted. Is there a way to modify this camera adjustment after finishing a sketch?
bradeneuropeArthur
does it help to uncheck the following options in the application options>
Arthur Knoors
Autodesk Affiliations:
Yes this worked great, thank you.
On a side note about customization, how difficult would it be for one to add the reorientation to face the camera at a sketch on creation but not on finishing?  Also the camera reorienting on completion wouldn't be so bad if it zoomed to fit instead of the default location, adding parameters to modify this default view.
I've tried setting the home view to something more comfortable but it doesn't seem to use the home view as the location.
bradeneuropeArthur
This is possible with this kind of method..
Public Sub K()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim c As Camera
Set c = b.Views.Item(1).Camera
Do something with events here..........
c.Apply
End Sub
Arthur Knoors
