A rule for adding and removing a solid body using a bounded pitch and length dimension.
maz
maz
Hello.I would need a rule for this problem.
1. Add or remove the "crossbar" body when changing the length so that the "control dimension" is in the range of 80-90mm.
If it doesn't work, get as close as possible to these dimensions.
2. At the same time mark the newly created "crossbar" so that they are also in "Rectangular pattern_B".
JelteDeJong
I think you can do part 1 without iLogic. You can use the following expressions for the parameters:
Number_of_crossbar = ceil(( Length - Width_crossbar ) / 80 mm) + 1 ul
spacing = ( Length - Width_crossbar ) / ( Number_of_crossbar - 1 ul )
and then use this in "Rectangular pattern_A"
Jelte de Jong
Blog: hjalte.nl - github.com
maz
Its not working.
