2015 assembly material change vba code is not functioning properly in 2016
Public Sub AssyMaterialChange()
' Check that an assembly is active.
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
MsgBox "An assembly must be active."
Exit Sub
' Get the active assembly document.
Dim asmDoc As AssemblyDocument
Set asmDoc = ThisApplication.ActiveDocument
' Get the custom property from the assembly and set it.
Call SetPropertyValue(asmDoc, "Design Tracking Properties", "Material", "(NS) S235")
' Iterate through all of the documents referenced by the assembly.
Dim Doc As Document
For Each Doc In asmDoc.AllReferencedDocuments
Call SetPropertyValue(Doc, "Design Tracking Properties", "Material", "(NS) S235")
Next
End Sub
Private Function SetPropertyValue(Doc As Document, PropertySetName As String, PropertyName As String, PropertyValue As Variant) As Boolean
' Attempt to get the specified property set.
Dim propSet As PropertySet
On Error Resume Next
Set propSet = Doc.PropertySets.Item(PropertySetName)
If Err.Number <> 0 Then
' Failed to get the specified property set. Return an error.
SetPropertyValue = False
Exit Function
' Attempt to get the specified property.
Dim prop As Property
Set prop = propSet.Item(PropertyName)
Err.Clear
' The property is not there, so create it.
Call propSet.Add(PropertyValue, PropertyName)
' Failed to add the property.
Exit Function
Else
prop.Value = PropertyValue
' Failed to set the value.
Exit Function
SetPropertyValue = True
End Function
If i run this code individual part material name not changing. When i call that part into idw its working. Plz help
