2 different dimensions?
khkon
khkon
Hello I have a dimmension on a drawing with dimmension 258,98. If I check that at the 3D-Modell it was 258. When i create the dimension  new it shows me correct, 258. I have not overwrote the old dimension.
mwighton
Check the precision of your measure tool and for dimensions in the drawing file.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
khkon
I found the issue. I change the drawing view from real (in german "ECHT") to parallel. Now it is correct. But I have no idea wy this has changed. Regards Klaus
