Hello, I've recently upgraded to Inventor 2021 and am trying to implement a registry edit that I did in Inventor 2019, but I'm having trouble finding the correct value, rather, it no longer exists.
In Inventor 2019 if you went to registry editor and navigated the following path: HKCU\Software\Autodesk\Inventor\RegistryVersionXX. 0\System\Preferences\Display
You would find a value called "Wheel Zoom Speed" which could be adjusted from its original value of 1 to 0.5, 0.25, so on and so forth. This would slice up the increment between zoom increments for the middle scroll button and allow for a better view within assemblies.
Does anyone know where I can find this value, or if it has been renamed in Inventor 2021? Thank you in advance.
