Zoom All
Zoom All
Zoom All
I want to do a "Zoom All"
In a sub I use
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim window As View
Set window = ThisApplication.ActiveView
window.Fit
But I want to do it from a VBA form with IV running.  I thought this might work, but no.
Dim oApp As Inventor.Application
Dim window As View
Set window = oApp.ActiveView
window.Fit
Any guidance would be appreciated.
I had another idea, I used a sub to do the window.Fit then added more code to show my form
Dim window As View
window.Fit
[the above works fine on it's own]
Load myForm
myForm.Show
The extra two lines stop the window.Fit working, but load myForm ready for use???
Now I am perplexed!!
Try the code in the attached Inventor 2010 part.
Is that what you're trying to do?
Mike
Yes it is.  Thanks for the assistance!
Just for your interest I've included the zoomAll call to the form activate so it happens smoothly when the form opens.
