Yes or No question, No isn't registering
AMN3161
AMN3161
I been staring at this for a while, doesn't anyone know why my VBNo is not registering when the dialog box comes up?
If System.IO.File.Exists(iProperties.Value("Custom", "Project_ Excel_File_Name")) = False Then
	Question5 = MessageBox.Show("The Project BOM was renamed or has been moved, Want to show me where is? If not I will make the link Inactive ", "iLogic Question", MessageBoxButtons.YesNo)
If Question5 = vbYes Then
				Dim oFileDlg1E As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg1E)
oFileDlg1E.InitialDirectory = oOrigRefName1E
oFileDlg1E.CancelError = True
On Error Resume Next
oFileDlg1E.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg1E.FileName <> "" Then
selectedfile1E = oFileDlg1E.FileName
MessageBox.Show("You selected: " & selectedfile1E, "iLogic")
iProperties.Value("Custom", "Project_ Excel_File_Name") = selectedfile1E
    Dim oAsm1F As AssemblyDocument = ThisDoc.Document
	Dim oDef1F As AssemblyComponentDefinition = oAsm1F.ComponentDefinition
	Dim pName1F As String = "Project_BOM" 'Property name here
	For Each oRefDoc1F As Document In oAsm1F.AllReferencedDocuments
	If oRefDoc1F.DocumentType = DocumentTypeEnum.kPartDocumentObject _
		AndAlso oDef1F.Occurrences.AllReferencedOccurrences(oRefDoc1F).Count > 0
		oRefDoc1F.PropertySets("Inventor User Defined Properties")(pName1F).Value = iProperties.Value("Custom", "Project_ Excel_File_Name")
	Next
Else If Question5 = vbNo Then
    MessageBox.Show("Do Stuff", "Title")
J-Camper
You had an End If separating the vbYes and vbNo If statements.  I added named lines relating to the If Statements for clarity:
I1:If System.IO.File.Exists(iProperties.Value("Custom", "Project_ Excel_File_Name")) = False Then
I2a:If Question5 = vbYes Then
I3a:	If Err.Number <> 0 Then
			Return
I3b:	ElseIf oFileDlg1E.FileName <> "" Then
E3:		End If
	'End If 'removed this end to join with Else If Below
L4:			If oRefDoc1F.DocumentType = DocumentTypeEnum.kPartDocumentObject _
E4:			End If
		Next
I2b:Else If Question5 = vbNo Then
E2:	End If 'Added End If
E1:End If
I# - If started
E# - If closed
AMN3161
Thank you, was just staring at this for so long i must of just missed that
