writing ilogic code
writing ilogic code
writing ilogic code
Hello, I am just getting in to the iLogic stuff and plan on writing most if not all of them initially to work in the HSM side as I work for the programming dept not the design side.
I have been watching a few tutorials, talked to a few people and many of those people offered up their best advise.
My question out of all of it as I will most likely have to dive a lot deeper in the coding to get what I want, can I write my iLogic code using C# or does it all have to be in vb?
I will eventually be jumping in to add ins and beyond the iLogic as I will eventually try and integrate out ERP system as well. Just curious if I can do the iLogic in C# or if I have to start in vb then switch to C# once I switch to add ins
Adam
Xun.Zhang
Hello Adam,
iLogic is built on top of VB rather than C#, however, you can directly interact with Inventor API with C#.
Hope it helps!
Xun
JaneFan
Hi @Anonymous ,
iLogic rules can only be written in VB language, but it can be called by iLogicAutomation in C# solution if you want to build you addin in this way; otherwise, using Inventor API directly is an alternative choice.
Jane Fan
Inventor/Fusion QA Engineer
