writing dwg with partnumber in titleblock
Message 1 of 1
Hi guys,
A large customer requires parts saved in dwg using their template with the drawing in model space and the template in paperspace in autocad. The models are made in 3d. The idw are then saved using "save copy as" as dwg files. Here you can specify a template. I can adjust line naming in inventor to map to the correct layers in autocad. But I would also want to save partsname en number so they automatically appear in the titleblock. in autocad. Doing this manually would be way to error prone and timeconsuming. Can somebody give me some pointers.
Maarten
Replies (0)
