Writing a subroutine or loop in iLogic rule
jfenter
Message 1 of 10
jfenter
I have the start of a code that needs to repeat 4 times.  I can recognize the need for a loop, but I don't know how to write it.
'Rule to position Block 1
preset1 = (railWidth + (blockWidth / 2) - oversize)
preset2 = length - railWidth - blockWidth / 2 + oversize
preset3 = innerRail1 - blockWidth / 2 - railWidth / 2
preset4 = innerRail1 + blockWidth / 2 + railWidth / 2
preset5 = innerRail2 - blockWidth / 2 - railWidth / 2
preset6 = innerRail2 + blockWidth / 2 + railWidth / 2
Select Case railCount
Case 0
	If block1position = 0 Then
		Feature.IsActive("Block1") = False
	ElseIf block1position = 1 Then
		Feature.IsActive("Block1") = True
		block1 = preset1
	ElseIf block1position = 2 Then
		block1 = preset2
	ElseIf block1position > 2 And block1position < preset1 Then
		MessageBox.Show("Block position not available in this configuration", "Block Position Error")
	ElseIf block1position >= preset1 Then
		block1 = block1position
Case 1
		block1 = preset1
		block1 = preset2
	ElseIf block1position = 3 Then
		block1 = preset3
	ElseIf block1position = 4 Then
		block1 = preset4
	ElseIf block1position > 4 And block1position < preset1 Then
Case 2
		block1 = preset1
		block1 = preset2
		block1 = preset3
		block1 = preset4
	ElseIf block1position = 5 Then
		block1 = preset5
	ElseIf block1position = 6 Then
		block1 = preset6
	ElseIf block1position > 6 And block1position < preset1 Then
End Select
There are 4 blocks that will be placed, so the above code needs to run for Block1, Block2, Block3 and Block4.  I assume I need to dimension the integer for the blocks and possibly also dimension the integer for the preset positions.  I think this should be an easy code to write, but I just don't know where to start.  Any help greatly appreciated.
Replies (9)
Message 2 of 10
Do while ... <>= ...
coding
Loop
Message 3 of 10
Curtis_Waguespack
Hi @jfenter
You could do something like this example.
In this case this simple example is just setting the OD parameter in each component (Block1, Block2, Block3 and Block4), but it shows how you hand the component name and parameter value from the main sub to the subroutine named "DoStuff" .
Sub Main
	For i = 1 To 4
		'assemble name string
		sName = "Block" & i
		'get current OD and add 1.125
		dOD = Parameter(sName, "OD") + 1.125
		'call sub routine, sending name and new OD value to the sub
		Call DoStuff (sName, dOD)
	Next i
	InventorVb.DocumentUpdate()
End Sub
Sub DoStuff (sName As String, dOD As Double)
	'update the OD parameter in the component
	'that matches the name string
	Parameter(sName, "OD") = dOD
End Sub
Message 4 of 10
jfenter
I'll give that a try.  I've been working toward something similar, but can't get it to work properly.  This is what I've got so far:
'*** Define Block Features
Dim blockfeature(4) As Object
blockfeature(1) = Feature.IsActive("Block1")
blockfeature(2) = Feature.IsActive("Block2")
blockfeature(3) = Feature.IsActive("Block3")
blockfeature(4) = Feature.IsActive("Block4")
'*** Define Block Dimension Parameter
Dim block(4) As Object
block(1) = block1
block(2) = block2
block(3) = block3
block(4) = block4
'*** Define Block Position Variable
Dim blockposition(4) As Double
blockposition(1) = block1position
blockposition(2) = block2position
blockposition(3) = block3position
blockposition(4) = block4position
Case 0
	For i = 1 To 4
	If blockposition(i) = 0 Then
		blockfeature(i) = False
	ElseIf blockposition(i)= 1 Then
		blockfeature(i) = True
		block(i) = preset1
	ElseIf blockposition(i) = 2 Then
		block(i) = preset2
	ElseIf blockposition(i) > 2 And blockposition(i) < preset1 Then
	ElseIf blockposition(i) >= preset1 Then
		block(i) = blockposition(i)
Next i
End Select
Message 5 of 10
Can you share your assembly so I can take a look at your definitions and where you go wrong?
Message 6 of 10
jfenter
The code I'm working on is "Rule 3".  The rule named "Block 1 Position" accomplishes what I want to do, but it needs repeated for blocks 2, 3 and 4.  I'm just looking for a way to condense the code into something easier to manage for debugging and updating later.
Message 7 of 10
I have a little peace of code added to your "block 1 position"
Here is what I added:
looking through all features
getting features with "Block"
Setting Block as a string with i attached
running the rules with Block + i
running your rule through block1 then adding +1 to string block so it becomes block2 excetra.
A messagebox as confirmation that it runs trough every block
Please accept as solution if you like it.
'API functions for features
Dim oFeature As PartFeature
Dim oFeatures As PartFeatures
oFeatures = ThisDoc.Document.ComponentDefinition.Features
Dim i As Integer = 1
'looks for all features containing Block and runs for Block 1 to 4
For Each oFeature In oFeatures
	If oFeature.Name.Contains("Block") = True
		Parameter.Quiet = True
		Dim Block As String = ("Block" & i)
Case 0
		Feature.IsActive(Block) = False
		Feature.IsActive(Block) = True
		block1 = preset1
		block1 = preset2
		MessageBox.Show(Block & " position not available in this configuration", "Block Position Error")
Case 1
		block1 = preset1
		block1 = preset2
		block1 = preset3
		block1 = preset4
		MessageBox.Show(Block & "position not available in this configuration", "Block Position Error")
Case 2
		block1 = preset1
		block1 = preset2
		block1 = preset3
		block1 = preset4
		block1 = preset5
		block1 = preset6
End Select
MsgBox  (Block)
i = i + 1
Next
Message 8 of 10
Sorry forgot the blockposition code so here is your full coding (Please note that is not fully foolproof)
		Dim blockpositiontussen As String = ("Block" & i & "position")
		Dim blockposition As Double = Parameter(blockpositiontussen)
		MsgBox(Block)
		MsgBox(blockposition & " = " & blockpositiontussen)
Case 0
	If blockposition = 0 Then
	ElseIf blockposition = 1 Then
		Block = preset1
	ElseIf blockposition = 2 Then
		Block = preset2
	ElseIf blockposition > 2 And blockposition < preset1 Then
	ElseIf blockposition >= preset1 Then
		Block = blockposition
Case 1
		Block = preset1
		Block = preset2
	ElseIf blockposition = 3 Then
		Block = preset3
	ElseIf blockposition = 4 Then
		Block = preset4
	ElseIf blockposition > 4 And blockposition < preset1 Then
Case 2
		Block = preset1
		Block = preset2
		Block = preset3
		Block = preset4
	ElseIf blockposition = 5 Then
		Block = preset5
	ElseIf blockposition = 6 Then
		Block = preset6
	ElseIf blockposition > 6 And blockposition < preset1 Then
End Select
i = i + 1
Next
Message 9 of 10
jfenter
That looks like it will work, but I'm out of the office all week.  I will test it at the end of the week and accept your solution if it works.  Thank you very much!
Message 10 of 10
Did it work for you?
Just want to make sure it works and doesn't couse any problems for you.
