Why my code sometimes works, sometimes doesn't ?
bjhuxq
bjhuxq
Rule1:
AddReference "Sobektech.InvCustomization.dll"
Imports Sobektech.InvCustomization.Ribbon
Public Class Test
	Public Sub main()
		Dim rb As RuleButton = New RuleButton(thisdoc.document, "Button", "My:Button1", "Show Form")
		rb.Add("Assembly", "id_TabAssemble", "MyPanel")
	End Sub
End Class
dll code:
using Autodesk.iLogic.Automation;
using Inventor;
using System.Collections.Generic;
using System.Linq;
namespace Sobektech.InvCustomization.Ribbon
    public class RuleButton
        public static List<RuleButton> RuleButtons = new List<RuleButton>();
        public Inventor.Application InvApp { get; private set; }
        public Inventor.Document Document { get; private set; }
        public string DisplayName { get; set; }
        public string InternalName { get; set; }
        public CommandTypesEnum Classification { get; set; }
        public string ToolTip { get; set; } = "";
        public string Description { get; set; } = "";
        public string RuleName { get; set; }
        public RuleButton(Document doc, string displayName, string internalName, string ruleName,CommandTypesEnum classification=CommandTypesEnum.kNonShapeEditCmdType, string toolTip="", string description="")
            Document = doc;
            InvApp = doc.File.Application;
            DisplayName = displayName;
            InternalName = internalName;
            Classification = classification;
            ToolTip = toolTip;
            Description = description;
            RuleName = ruleName;
            RuleButtons.Add(this);
        public void Add(string ribbon,string tab,string pannel)
            Inventor.ButtonDefinition bd = InvApp.CommandManager.ControlDefinitions.OfType<ButtonDefinition>().FirstOrDefault(b => b.InternalName == InternalName);
            if(bd== null)
                bd = InvApp.CommandManager.ControlDefinitions.AddButtonDefinition(DisplayName, InternalName, Classification, "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}", DescriptionText:Description,ToolTipText:ToolTip);
                bd.Enabled = true;
                bd.OnExecute += ButtonDefinition_OnExecute;
                InvApp.UserInterfaceManager.Ribbons[ribbon].RibbonTabs[tab].RibbonPanels.Add(pannel, InternalName + pannel, "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}").CommandControls.AddButton(bd);
            else
                bd.Enabled = true;
        public void ButtonDefinition_OnExecute(NameValueMap context)
            System.Windows.Forms.MessageBox.Show("Button Clicked!");
            if (GetiLogicAutomation(InvApp, out iLogicAutomation iLogicAutomation))
                System.Windows.Forms.MessageBox.Show("Got iLogic !");
            iLogicAutomation.RunRule(Document, RuleName);
        public static bool GetiLogicAutomation(Inventor.Application invApp, out Autodesk.iLogic.Automation.iLogicAutomation iLogic)
            ApplicationAddIns addIns = invApp.ApplicationAddIns;
            ApplicationAddIn addIn;
            try
                addIn = addIns.ItemById["{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}"];
                addIn.Activate();
                iLogic = addIn.Automation as iLogicAutomation;
                return true;
            catch
                iLogic = null;
                return false;
dll code  using vb.net :
Imports Autodesk.iLogic.Automation
Imports Inventor
Imports System.Collections.Generic
Imports System.Linq
Imports System.Runtime.InteropServices
Namespace Sobektech.InvCustomization.Ribbon
    Public Class RuleButton
        Private _InvApp As Inventor.Application, _Document As Inventor.Document
        Public Shared RuleButtons As List(Of RuleButton) = New List(Of RuleButton)()
        Public Property InvApp As Application
            Get
                Return _InvApp
            End Get
            Private Set(ByVal value As Application)
                _InvApp = value
            End Set
        End Property
        Public Property Document As Document
            Get
                Return _Document
            End Get
            Private Set(ByVal value As Document)
                _Document = value
            End Set
        End Property
        Public Property DisplayName As String
        Public Property InternalName As String
        Public Property Classification As CommandTypesEnum
        Public Property ToolTip As String = ""
        Public Property Description As String = ""
        Public Property RuleName As String
        Public Sub New(ByVal doc As Document, ByVal displayName As String, ByVal internalName As String, ByVal ruleName As String, ByVal Optional classification As CommandTypesEnum = CommandTypesEnum.kNonShapeEditCmdType, ByVal Optional toolTip As String = "", ByVal Optional description As String = "")
            Document = doc
            Me.DisplayName = displayName
            Me.InternalName = internalName
            Me.Classification = classification
            Me.ToolTip = toolTip
            Me.Description = description
            Me.RuleName = ruleName
            RuleButtons.Add(Me)
        End Sub
        Public Sub Add(ByVal ribbon As String, ByVal tab As String, ByVal pannel As String)
            Dim bd As ButtonDefinition = InvApp.CommandManager.ControlDefinitions.OfType(Of ButtonDefinition)().FirstOrDefault(Function(b) Equals(b.InternalName, InternalName))
            If bd Is Nothing Then
                bd = InvApp.CommandManager.ControlDefinitions.AddButtonDefinition(DisplayName, InternalName, Classification, "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}", DescriptionText:=Description, ToolTipText:=ToolTip)
                bd.Enabled = True
                AddHandler bd.OnExecute, AddressOf ButtonDefinition_OnExecute
                InvApp.UserInterfaceManager.Ribbons(ribbon).RibbonTabs(tab).RibbonPanels.Add(pannel, InternalName & pannel, "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}").CommandControls.AddButton(bd)
            Else
                bd.Enabled = True
        End Sub
        Public Sub ButtonDefinition_OnExecute(ByVal context As NameValueMap)
            Dim iLogicAutomation As iLogicAutomation = Nothing
            If GetiLogicAutomation(InvApp, iLogicAutomation) Then Windows.Forms.MessageBox.Show("Got iLogic !")
        End Sub
        Public Shared Function GetiLogicAutomation(ByVal invApp As Application, <Out> ByRef iLogic As iLogicAutomation) As Boolean
            Dim addIns = invApp.ApplicationAddIns
            Dim addIn As ApplicationAddIn
            Try
                addIn = addIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
                addIn.Activate()
                iLogic = TryCast(addIn.Automation, iLogicAutomation)
                Return True
            Catch
                iLogic = Nothing
                Return False
            End Try
        End Function
    End Class
End Namespace
result:
Cadkunde.nl
I haven't tried your code.
My feeling, glancing your code, I think it might be because of the Guid.
Instead of a fixed Guid, try:
Guid.NewGuid().ToString()
But if you are this far and knowledgable in coding.
I suggest make a real addin which shows the button.
I've never tried it this way, and must be hard debugging.
bjhuxq
I can make Addin ribbon button, but this time I want ribbon button appear when others open my .iam file. If I make a Addin, the button will appear everytime.I try to give a new guid ,and it works very well, thanks!
using Inventor;
using System;
using System.Linq;
        private RibbonPanel _panel;
        private Inventor.ButtonDefinition _bd;
            Document = doc;
            ToolTip = toolTip;
            doc.DocumentEvents.OnClose += DocumentEvents_OnClose;
        private void DocumentEvents_OnClose(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
            _panel.Delete();
            _bd.Delete();
            HandlingCode=HandlingCodeEnum.kEventHandled;
            if(bd== null)
                string classId = "{" + Guid.NewGuid().ToString() + "}";
                bd = InvApp.CommandManager.ControlDefinitions.AddButtonDefinition(DisplayName, InternalName, Classification, classId, DescriptionText:Description,ToolTipText:ToolTip);
                bd.Enabled = true;
                _panel = InvApp.UserInterfaceManager.Ribbons[ribbon].RibbonTabs[tab].RibbonPanels.Add(pannel, InternalName + pannel, classId);
                _panel.CommandControls.AddButton(bd);
            else
                bd.Enabled = true;
            _bd = bd;
            try
                addIn.Activate();
                return true;
            catch
                iLogic = null;
                return false;
Cadkunde.nl
I think I would still make an addin, display the button.
But let the button do nothing unless some hidden check, like you add a custom iproperty "SebekTech" = True
Debugging is better that way, but also the button now does not dissappear when switching, so the problem still exists of misuse.
With an addin you can even use the inventor event on document chance, check if custom iproperty exist and show button and hide if not
