Why do some dimensions appear in mm and others in m in i-Logic Form? Also in general in the whole assembly. I have changed all units to mm and degrees in Tools>Doc Settings>Units.
hhristov88
hhristov88
Pleas see the attached jpeg.
Accepted solutions (3)
FINET_Laurent
Hi @hhristov88,
What about the parameter tab ?
You can specify an unit by double-clicking the unit of the parameter :
Sorry for baguette language.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
hhristov88
I only added the "Key" parameters here, but in general all of them are locked (greyed out) Nothing happens when I double clicked. I also noticed that your parameters are in "User parameters" tab, not Model parameter tab. I do not have anything in the User parameter tab. (See below)
FINET_Laurent
@hhristov88,
I did some testing. The value indicated in the form is the value of the said parameter. If I override the value with a new one, and also specifying the unit, for instance if I type "4m" in the parameter value cell, it will display "4m" in the iLogic form, regardless of the document default units. I guess you simply need to do this step for every parameters that causes the issue.
Newly created dimensions and parameters will have the correct unit.
Kind regatds,
FINET L.
hhristov88
I think that will solve it, I will test it out on Monday!
Merci!
hhristov88
It worked, thanks a lot!
