Why do iAssembly Factory BOMs give incorrect ComponentOccurance data for inactive BOM lines?
I'm trying to traverse the BOM of an iAssembly Factory assembly with multiple configurations and extract the BOM to a custom data interchange format for our awful ERP system.
I can parse through the BOM rows no problem, but when I go to extract data from "inactive" BOM row (i.e.: from a different line in the iFactory table than is currently active) the data I get out is incorrect.
This presents as follows:
1st BOM line (Active) is Item #1, Name is Part1 '<-Outputs as expected
2nd BOM line (Inactive) is Item#2, Name is Part2 '<- Item # correct "2" but Outputs Part1 Again
3nd BOM line (Inactive) is Item#2, Name is Part3 '<- Item # correct "3" but Outputs Part1 Again
37th BOM line (Finally another Active Line) is Item#37, Name is Part37 '<-Outputs correctly again
38th BOM line (Inactive) is Item#38, Name is Part37 '<- Item # correct "37" but Outputs Part37 Again
etc...
I can see this data (Correctly) in "All Members" view of the BOM in inventor. I know the correct data is in there somewhere. How do I get it out? Surely there has to be a better solution than traversing all the instances and ignoring zero qty lines then adding it all together at the end?
Problem lines:
'Traverse the BOM For Each oBOMRow In oAssyBOMRows oComponentOcc = oBOMRow.ComponentOccurrences.Item(1) 'Get first occurrence of each BOM line item to suck out it's parameters. 'MYSTERIOUSLY DOESNT WORK ON iAssembly parts :-/ Just stays stuck on the last "Active" instance instead '<TODO> Add Support for Instance Properties? oComponentName = oComponentOcc.Name
Full Sub minus some excel stuff that I've redacted.:
Sub Main() 'Document Level Variable Definitions Dim oDocType As DocumentTypeEnum = ThisDoc.Document.DocumentType Dim oDocFileName As String = ThisDoc.FileName(False) 'without extension Dim oDocPath As String = ThisDoc.Path 'Assembly Level Variable Definitions Dim oAssyDoc As AssemblyDocument = Nothing Dim oAssyCompDef As AssemblyComponentDefinition = Nothing Dim oAssyName As String = Nothing 'iAssembly Variable Definitions Dim oAssyFactory As iAssemblyFactory = Nothing Dim oFactoryRowCount As Integer = 0 'Default of 0 means NOT a factory 'BOM Variable Definitions Dim oAssyBOM As BOM = Nothing Dim oAssyBOMView As BOMView = Nothing Dim oAssyBOMRows As BOMRowsEnumerator = Nothing 'Components definition variables(Not needed?) 'Dim oAssyComponents As ComponentOccurrences = Nothing 'Dim oAssyComponentsCount As Integer = 0 'Check that this part is an Assembly If oDocType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("This Script is intended for Assemblies ONLY", MessageBoxIcon.Error, "Error - Wrong Document Type") : Exit Sub Else 'If so, Then get Links to Assembly Document Objects oAssyDoc = ThisApplication.ActiveDocument oAssyCompDef = oAssyDoc.ComponentDefinition oAssyName = oAssyDoc.DisplayName If oAssyCompDef.IsiAssemblyFactory Then 'IF factory assembly, then get Factory Object and row Count. oAssyFactory = oAssyCompDef.iAssemblyFactory 'Returns Nothing if not a Factory Assembly oFactoryRowCount = oAssyFactory.TableRows.Count End If ' oAssyComponents = oAssyCompDef.Occurrences ' oAssyComponentsCount = oAssyCompDef.Occurrences.Count oAssyBOM = oAssyCompDef.BOM oAssyBOM.StructuredViewEnabled = True oAssyBOM.StructuredViewFirstLevelOnly = True '<TODO> Add Capabilities for multi-level BOMs. NOTE multilevel BOMS are NOT COMPATIBLE w iFactories. oAssyBOMView = oAssyBOM.BOMViews.Item("Structured") oAssyBOMRows = oAssyBOMView.BOMRows End If 'BOM ITEM Variable Definitions Dim oBOMRow As BOMRow Dim oComponentOcc As ComponentOccurrence = Nothing Dim oComponentDef As ComponentDefinition = Nothing Dim oComponentDoc As Document = Nothing Dim oComponentName As String = Nothing Dim oComponentNameAndPath As String = Nothing Dim oBOMRowItemNum As String = Nothing Dim oComponentPartNumber As String = Nothing 'Dim oComponentDescription As String = Nothing 'Dim oComponentDwgNum As String = Nothing 'Dim oComponentMatl As String = Nothing 'Property Sets of Component Variables 'Dim oInstanceProps As PropertySet = Nothing Dim oSummaryProps As PropertySet = Nothing 'Summary Tab Properties except Manager, Company, and Category Dim oDocumentProps As PropertySet = Nothing 'Only Manager, Company, and Category Dim oDesignTrackingProps As PropertySet = Nothing 'This is the Main one for Project, status, etc... Dim oUserProps As PropertySet = Nothing 'Anything User Added within the child parts themselves. 'oBOMRow.ComponentDefinitions Dim i As Integer = 0 ' Debugging Count Variable Dim j As Integer = 0 ' Debugging Count Variable 'Traverse the BOM For Each oBOMRow In oAssyBOMRows oComponentOcc = oBOMRow.ComponentOccurrences.Item(1) 'Get first occurance of each BOM line item to suck out it's parameters. 'MYSTERIOUSLY DOESNT WORK ON iAssembly parts :-/ Just stays stuck on the last "Active" instance instead '<TODO> Add Support for Instance Properties? oComponentName = oComponentOcc.Name oComponentDoc = oComponentOcc.Definition.Document 'MAGIC Document grabbing undocumented BS oComponentName = oComponentDoc.DisplayName oComponentNameAndPath = oComponentDoc.File.FullFileName oBOMRowItemNum = oBOMRow.ItemNumber 'Get sub-part/assembly stored Properties oSummaryProps = oComponentDoc.PropertySets.Item("Inventor Summary Information") oDocumentProps = oComponentDoc.PropertySets.Item("Inventor Document Summary Information") oDesignTrackingProps = oComponentDoc.PropertySets.Item("Design Tracking Properties") oUserProps = oComponentDoc.PropertySets.Item("Inventor User Defined Properties") oComponentPartNumber = oDesignTrackingProps.Item("Part Number").Value 'Debugging Nonsense If i < 50 Then MsgBox(oComponentOcc.ActiveModelState & " " & oBOMRowItemNum & " " & oBOMRow.ComponentOccurrences.Count & " " & oComponentName) i = i + 1 ' If oComponentPath.Contains("Content Center Files") Then ' '<TODO> STUFF TO LIBRARY PARTS <TODO> ' End If Next
