Why DataIO sample code in API help does not work?
04:38 PM
I followed the sample code and opened a part file before run it. Why I got an error(Method 'WriteDataToFile' of object '_IRxDataIO' failed)? What did I do wrong?
The Code:
Public Sub WriteSheetMetalDXF()
' Get the active document. This assumes it is a part document.
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
' Get the DataIO object.
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
' Build the string that defines the format of the DXF file.
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=Outer"
' Create the DXF file.
oDataIO.WriteDataToFile sOut, "c:\temp\flat2.dxf"
End Sub
The Code:
Dim sOut As String
End Sub
