Why are all of these components seperate?
Message 1 of 9
Good god why the !@$% do I have to download all this other nonsense when all I needed was inventor so that I can build one project for a class?  AND NOW SINCE YOUR PROGRAM CORRUPTED ITS OWN LICENSE OR SOME CRAP I HAVE TO UNINSTALL 18 !@$%ING COMPONENTS AND REINSTALL THEM. GOSH I HOPE THERE ARE NO COMPLICATIONS FROM THIS.  Although I'm sure it still won't work.  Because without an IT department, like my school has, there is no way a program this freaking unorganized will work without serious troubleshooting.
1 project is all I freaking needed to work one. JUST ONE.  This is a monumental waste of my time.
Replies (8)
Message 2 of 9
Seriously?  I have to shut down windows explorerer in order for one of these components to uninstall?
Message 3 of 9
OH LOOK, THE LIBRARIES WON'T UNINSTALL BECAUSE THERE IS NO PATHWAY TO THEM.  WAT.
No wonder support does not seem to be able to be contacted directly.
Message 4 of 9
What a surprise, it didn't work. GOOD JOB AUTODESK
Message 5 of 9
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
Sorry to hear you're having the issue with Inventor! Could you please try the solution in this article: The application was unable to start correctly (0xc0000022). Click OK to close the application ? Let us know if it works.
Lynn Zhang
Message 6 of 9
WTF?  That isn't even the correct error code.
Message 7 of 9
8:19:26.4099662 PM Inventor.exe 10932 RegCreateKey HKLM\SOFTWARE\Policies\Microsoft\SystemCertificates\Root ACCESS DENIED Desired Access: Read/Write, Delete
They are all like this.
HKLM\SOFTWARE\Policies\Microsoft\SystemCertificates\CA
HKLM\SOFTWARE\Policies\Microsoft\SystemCertificates\Disallowed
HKLM\SOFTWARE\Policies\Microsoft\SystemCertificates\AuthRoot
HKLM\SOFTWARE\Policies\Microsoft\SystemCertificates\SmartCardRoot
They are all registry keys, not sure how I am supposed to get to those files without regeditor.
And yeah there are more than I posted.
Message 8 of 9
rhasell
When you are finished spitting the dummy, perhaps you can come back to the forum with descent information and a descent request for help.
With an attitude like that, you will get very little help, if at all.
Maybe then people might be inclined to offer assistance.
Reg
2026.1
Message 9 of 9
rhasell
See if this helps.
Before you complain, it's a possible solution for Product design suite as well.
http://forums.autodesk.com/t5/installation-licensing/error-0xc000007b-while-starting-autocad-2013/td...
The error is normally something wrong with your OS. (Dotnet, Visual C, DirectX)
Make sure you use the uninstall tool to remove the failed installation.
Make sure you are running as admin.
Disable your AntiVirus.
Disable your UAC
Reg
2026.1
