Which inventor addin template
NachoShaw
Advisor Advisor
NachoShaw
Hey
Mixed bag today of results. Which template is better?
The nifty template from Brian, its out of date but easy to set up**
The 2024 template that appears in the visual studio templates. It's up to date but much harder to set up**
**nothing about how to prep an icon with any of them. I've tried .ico, .png but nothing...
NSS RAIN. Was actually great but it's out date and the developers don't really care for it anymore
Are there any other templates out there?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Michael.Navara
It depends on your needs. How many addins you plan to create?
I have created tens of addins for end customers and I have created my own template. But it is only slightly modified default template.
Lot of functionality I put into my own DLL library which I reference to all projects. This library contains for example Command wrapper for easy command creation, converter from ICO file to IPictureDisp for command icons (similar to this), extension methods for CommandManager.PromptMessage which converts the behavior near to the  WinForms MessageBox and many more.
In my opinion this is the best approach for anyone, who plan to create and maintain more then one or two addins.
yan.gauthier
For Icons, you can simply Convert from an Image to IPictureDisp using Stdole.dll :
   internal class AxHostConverter : AxHost
       private AxHostConverter() : base("") { }
       static public stdole.IPictureDisp ImageToPictureDisp(Image image)
           return (stdole.IPictureDisp)GetIPictureDispFromPicture(image);
       static public Image PictureDispToImage(stdole.IPictureDisp pictureDisp)
           return GetPictureFromIPicture(pictureDisp);
An Image can be anything such as a Bitmap. Only requisites is that it respect the sizing (16x16 for small icons, 32x32 for big icons).
bretrick30
Hey,
I created an Addin template to try and make adding buttons to the ribbon as simple as possible, with icons. It is available on GitHub.
bretleasure/Inventor.AddinTemplate: Easy to use C# template for creating Autodesk Inventor Addins (g...
j.romoYDW7Q
I really found easier to start from scatch following Jelte de Jong tutorials, now i do them easy.
http://hjalte.nl/tutorials
Just my 2 cents.
Curtis_Waguespack
Hi @NachoShaw
You can find a couple of simplified add-in templates from an Autodesk University class I presented last fall at this link:
Bridging the Gap Between iLogic Automation and Inventor Add-Ins | Autodesk University
Here is a direct link to the *.zip file because the AU page is showing it as a PDF icon for some reason
https://static.au-uw2-prd.autodesk.com/Additional-Materials-MFG601910-CurtisWaguespack-AU2023_170171...
This class walks you through how to spin up a basic add-in that comes with some simple buttons that you can configure to your liking, and/or you can add to it and create your own.
And also has another template that comes with some of the more advanced "button stacks" with dropdowns, etc. that you can also configure to your liking, and/or you can add to it and create you own:
I hope this helps.
Curtis
NachoShaw
much appreciated for the responses. A further question: Over the weekend i took Brians existing 2018 Nifty addin and updated it to 2024, updated so Post Build events, added some template ribbon code for drawings & assemblies and then saved it back in the same format as the original. When i added to the templates folder for VS, it wouldnt show. Is there a file i need to add the template to or a registry key that needs adding?
Thanks again
Nacho
