Where do I turn when no one posts the answer to my question (kParameterIntent)?
rfink
rfink
I have requested and explanation regarding the Geometry Intent functionality when using the kParameterIntent IntentType and Double Intent Value.
Somehow it positions the Geometry Intent along the Intent Geometry (i.e. drawing curve) based on the Intent Value, but I don't know how.
There is some info in the API Help regarding this, but I can't get it to work as needed.
Where do I turn when no one posts the answer to my question (how to use the kParameterIntent Intent Type)?
rikard.nilsson
My experience is that you need to ask quite direct question to get good answers.
Things that you can add is.
Describing text
Pictures
Example code/Files of what you got so far.
And if you don’t get answers then Autodesk will step in and help you.
If you read your post in a computer then you can press a button below that says something like “Request Answer”. That will send a message to Autodesk.
Regards
Rikard
