What's the HoleThreadNote text format?
bwang-tecoustics
bwang-tecoustics
I want to replace the word in a HoleThreadNote but not succeed. Per the screenshot below, I can't figure out what is the HoleThreadNote text format. It's different than other drawing notes, and even different than dimensions. Any ideas?
Image shows the value I got from FormattedText property and Text property of the HoleThreadNote.
bwang-tecoustics
This is crazy.
I finally find that the text of the HoleThreadNote is called FormattedHoleThreadNote and I'm able to replace the word in it. But, after the word is replaced, the Hole callout shows this plus/minus 0 symbol. I don't know where it was from and I can't find it in the note editor. It's simply showup.
bwang-tecoustics
The code I used is:
mHTNote.FormattedHoleThreadNote = mHTNote.FormattedHoleThreadNote.Replace("red fox", "blue box")
And it makes location 1 to be turned off, and 2 to be turned on. I don't know what caused this to be triggered with a text replace. See below.
xiaodong_liang
Autodesk Support
Autodesk Support
I can reproduce this issue, but did not find how to reset it. I will log a ticket in the internal tracking system with our engineer team.
This is the dataset I tested with.
  1. open the attached drawing
  2. run the VBA code below
the 'red' is replaced with 'blue', but the tolerance sign is toggled on.
Sub test()
 Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oHoleNote As HoleThreadNote
For Each oHoleNote In oDoc.ActiveSheet.DrawingNotes.HoleThreadNotes
Debug.Print oHoleNote.Text.Text
Dim oldFormattedText As String
oldFormattedText = oHoleNote.FormattedHoleThreadNote
Debug.Print oldFormattedText
Dim newFormattedText As String
newFormattedText = Replace(oldFormattedText, "red", "blue")
Debug.Print newFormattedText oHoleNote.FormattedHoleThreadNote = newFormattedText
Next
End Sub
xiaodong_liang
Autodesk Support
Autodesk Support
As said, I logged the issue: INVGEN-9413
bshbsh
Thanks. I have the same problem. post1, post2
Hope it gets solved now.
clutsa
In INVGEN-9413 is there a way to turn the tolerance toggle off with API? I see it's been a little over a year and was just wondering if this was resolved?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
