What is the syntax used in Visual Studio (VB.NET) to show output?
HI ALL,
         I used Ilogic to create an model with allowing the clients to give inputs. In the below image, Radius (R) and Thickness (t) are read-only property which means the output of thickness will be shown according to the input given.
In this image, the thickness value is a read-only memoryIn this image, the thickness value is a read-only memorySo, I need the syntax to show the value of thickness in visual studio using VB.NET
I also what to know what is the tool is used to the output of this thickness which is calculated using the input given. Please try to help me ASAP.
Thanks in Advance
Michael.Navara
You need to calculate result (thickness in this case) in function. To this function you send parameters and result display in textBox.
This function can be called when some event occurrs. For example textBox.TextChanged on all input textboxes.
I will give inputs only to the above four parameters and the value of thickness will be calculated in the ilogic and the output should be shown in the highlighted box
Michael.Navara
No sir, I am not Using ilogic in VS. I have already linked them in inventor.
 I am just linking the parameter in Visual Studio using Code with inventor. So that, The output of thickness should shown
Michael.Navara
In common workflow (from iLogic snippets/wizzard) you don't bind "parameter" to form but only its value. Therefore, you must perform the calculations manually in the form.
In iLogic form is implemented functionality for update parameter value after value change in form (and all dependent calculations). You can implement this, but IMHO this is overkill for this reason.
Ok Sir, I will try manually in the windows form in Visual Studio
