Weld - XML Info
Weld - XML Info
Weld - XML Info
Hi guys,
I tried to get the XML-Information of a weld. But the string that should contain this information is empty. Did I make a mistake?, or is this feature not supported by Inventor 2014 anymore. Even the helping page "More XML Weld Info..." in the Programmershelp doesn't exist anymore and leads to an error.
This is my VBA-Code to show the XML-Info string for each weld within the assembly in a message box:
Sub WeldInfo()
    'is the active document an assembly?
    If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        Return
    Dim IamDoc As AssemblyDocument
    Set IamDoc = ThisApplication.ActiveDocument
    Dim ComDef As AssemblyComponentDefinition
    Set ComDef = IamDoc.ComponentDefinition
    Dim ComOccS As ComponentOccurrences
    Set ComOccS = ComDef.Occurrences
    Dim ComOcc As ComponentOccurrence
    For Each ComOcc In ComOccS
        If ComOcc.Type = ObjectTypeEnum.kComponentOccurrenceObject Then
            Dim Def As ComponentDefinition
            Set Def = ComOcc.Definition
            'If the occurence is a weld
            If Def.Type = ObjectTypeEnum.kWeldsComponentDefinitionObject Then
                Dim WelComDef As WeldmentComponentDefinition
                Set WelComDef = ComDef
                Dim WelS As Welds
                Set WelS = WelComDef.Welds
                Dim WelBeaS As WeldBeads
                Set WelBeaS = WelS.WeldBeads
                'For each WeldBead display the XML-Information
                Dim WelBea As WeldBead
                    For Each WelBea In WelBeaS
                    'Display the XML String
                    MsgBox ("name: " & WelBea.Name & " XML-Info: " & WelBea.WeldInfo)
                    Next
                    MsgBox ("finished")
    Next
End Sub
For Your help I would be grateful
I found the solution. The XML-Info String only provides the Information of the weld symbol. So you have to add a weld symbol to the weld first. Then you can read the XML-String.
