Weird error in rule
Weird error in rule
Weird error in rule
SyntaxEditor Code Snippet
'Wrijvingsco?ici?
If Type_Band = "TPU - glad, antistatisch, hydrolysebestendig [EMB-12EMCH] Habasit" Then
Wrijvingscoëfficiënt_Band = 0.20
ElseIf Type_Band = "TPU - stroef, antistatisch, frayless [TT12 Matt Blue Frayless] Habasit" Then
ElseIf Type_Band = "Nonex EE/1 00+05 Light Blue M2 FG AM [SBNO585031] Ammeraal Beltech" Then
Wrijvingscoëfficiënt_Band = 0.70
'Dikte Band
Dikte_Band = 1.70
Dikte_Band = 1.30
Dikte_Band = 1.60
'Gewicht per meter
Massa_per_m2 = 1.80
Massa_per_m2 = 1.40
Massa_per_m2 = 1.60
This is a part of a rule I have. When I run the rule it gives the error:
The unit name "Light Blue M2 FG AM"is not valid in Inventor.
I find this quite strange...
I have a text parameter "Type_Band" with the possibilities:
"Nonex EE/1 00+05 Light Blue M2 FG AM [SBN0585031] Ammeraal Beltech"
 I copy pasted everything in the rule, so there can't be any errors in the names not matching.
Even weirder is. If I copy litterly this part of the code in another rule without the rest of the rule, it works perfectly fine.
I hope someone can help me out!
Melle Oosterman
Inventor 2014
EelcoWiggers
Hi Melle,
Can you post the other part (full code of the rule) of the code? You say that this part of the code gives no error when placed in a other rule without the rest of the code. I assume the error is triggert by some other line in your code.
Eelco
Sure, but I'm still pretty sure it's in this part of the code. If I remove the few words "Light Blue M2 FG AM" the error won't occur. (But then the code doesn't work anymore).
Here's the full code:
RUSure = MessageBox.Show _
("Are you sure you want to run this rule?,  _"iLogic",MessageBoxButtons.YesNo)
If RUSure = vbNo Then
Return
Else
'Wrijvingscoëfficiënt?
'Dikte Band
Dikte_Band = 1.70
Dikte_Band = 1.30
Dikte_Band = 1.60
'Gewicht per meter
Massa_per_m2 = 1.80
Massa_per_m2 = 1.40
Massa_per_m2 = 1.60
'Soort Motor
If Vermogen_Band <= 0.124 kW Then
Soort_Motor = 0.12 kW
ElseIf Vermogen_Band > 0.124 kW And Vermogen_Band <= 0.184 kW Then
Soort_Motor = 0.18 kW
ElseIf Vermogen_Band > 0.184 kW And Vermogen_Band <= 0.254 kW Then
Soort_Motor = 0.25 kW
ElseIf Vermogen_Band > 0.254 kW And Vermogen_Band <= 0.374 kW Then
Soort_Motor = 0.37 kW
ElseIf Vermogen_Band > 0.374 kW And Vermogen_Band <= 0.554 kW Then
Soort_Motor = 0.55 kW
ElseIf Vermogen_Band > 0.554 kW And Vermogen_Band <= 0.754 kW Then
Soort_Motor = 0.75 kW
ElseIf Vermogen_Band > 0.754 kW And Vermogen_Band <= 1.14 kW Then
Soort_Motor = 1.1 kW
ElseIf Vermogen_Band > 1.14 kW And Vermogen_Band <= 1.54 kW Then
Soort_Motor = 1.5 kW
ElseIf Vermogen_Band > 1.54 kW And Vermogen_Band <= 2.24 kW Then
Soort_Motor = 2.2 kW
'Instelling rem
If Rem_Motor = "-" Then
MultiValue.SetList("Handremlichter", "-")
ElseIf Rem_Motor = "-" Then
Handremlichter = "-"
ElseIf Rem_Motor = "Veerdrukrem" Then
MultiValue.SetList("Handremlichter", "-", "Vastzetbaar")
'Type_Motor zonder "Rem_Motor" en zonder "Handremlichter"
If Soort_Motor = 0.12 kW And Rem_Motor = "-" And Handremlichter = "-"
Type_Motor = "DRS71S4"
ElseIf Soort_Motor = 0.18 kW And Rem_Motor = "-" And Handremlichter = "-"
ElseIf Soort_Motor = 0.25 kW And Rem_Motor = "-" And Handremlichter = "-"
ElseIf Soort_Motor = 0.37 kW And Rem_Motor = "-" And Handremlichter = "-"
ElseIf Soort_Motor = 0.55 kW And Rem_Motor = "-" And Handremlichter = "-"
Type_Motor = "DRS71M4"
ElseIf Soort_Motor = 0.75 kW And Rem_Motor = "-" And Handremlichter = "-"
ElseIf Soort_Motor = 1.1 kW And Rem_Motor = "-" And Handremlichter = "-"
Type_Motor = "DRE90M4"
ElseIf Soort_Motor = 1.5 kW And Rem_Motor = "-" And Handremlichter = "-"
ElseIf Soort_Motor = 2.2 kW And Rem_Motor = "-" And Handremlichter = "-"
Type_Motor = "DRE100M4"
'Type_Motor met "Rem_Motor" en zonder "Handremlichter"
If Soort_Motor = 0.12 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
Type_Motor = "DRS71S4 BE05"
ElseIf Soort_Motor = 0.18 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
ElseIf Soort_Motor = 0.25 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
ElseIf Soort_Motor = 0.37 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
ElseIf Soort_Motor = 0.55 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
Type_Motor = "DRS71M4 BE1"
ElseIf Soort_Motor = 0.75 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
Type_Motor = "DRE71M4 BE1"
ElseIf Soort_Motor = 1.1 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
Type_Motor = "DRE90M4 BE2"
ElseIf Soort_Motor = 1.5 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
ElseIf Soort_Motor = 2.2 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "-"
Type_Motor = "DRE100M4 BE5"
'Type_Motor met "Rem_Motor" en met "Handremlichter"
If Soort_Motor = 0.12 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
Type_Motor = "DRS71S4 BE05 HF"
ElseIf Soort_Motor = 0.18 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
ElseIf Soort_Motor = 0.25 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
ElseIf Soort_Motor = 0.37 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
ElseIf Soort_Motor = 0.55 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
Type_Motor = "DRS71M4 BE1 HF"
ElseIf Soort_Motor = 0.75 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
Type_Motor = "DRE71M4 BE1 HF"
ElseIf Soort_Motor = 1.1 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
Type_Motor = "DRE90M4 BE2 HF"
ElseIf Soort_Motor = 1.5 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
ElseIf Soort_Motor = 2.2 kW And Rem_Motor = "Veerdrukrem" And Handremlichter = "Vastzetbaar"
Type_Motor = "DRE100M4 BE5 HF"
'Type Reductor
Uitvoering_Reductor = "Voetuitvoering"
Eigenschappen_Reductor = "Holle As"
If Opties_Reductor = "Met reactiearm" Then
Optie_Reductor = "/T"
If Soort_Motor = 0.12 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
Type_Reductor = "KA19B"
ElseIf Soort_Motor = 0.12 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
Type_Reductor = "SA37"
ElseIf Soort_Motor = 0.18 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 0.18 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 0.25 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 0.25 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 0.37 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 0.37 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 0.55 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 0.55 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 0.75 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 0.75 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 1.1 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 1.1 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
Type_Reductor = "SA47"
ElseIf Soort_Motor = 1.5 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
Type_Reductor = "KA29B"
ElseIf Soort_Motor = 1.5 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
ElseIf Soort_Motor = 2.2 kW And Soort_Reductor = "Kegelwielmotorreductoren Serie K" Then
ElseIf Soort_Motor = 2.2 kW And Soort_Reductor = "Wormwielmotorreductoren Serie S" Then
'Encoder
MultiValue.SetList("Encoder","-", "1", "2", "6", "24")
'Opties_Motor DRS 71S 4
If Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "-" Then
Opties_Motor = "/MM03/MO/AZZK"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "-" Then
Opties_Motor = "/MM03/MO/AZZK/EI71"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "-" Then
Opties_Motor = "/MM03/MO/AZZK/EI72"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "-" Then
Opties_Motor = "/MM03/MO/AZZK/EI76"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "-" Then
Opties_Motor = "/MM03/MO/AZZK/EI7C"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/MM03/MO/AZZK/LN"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/MM03/MO/AZZK/EI71/LN"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/MM03/MO/AZZK/EI72/LN"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/MM03/MO/AZZK/EI76/LN"
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/MM03/MO/AZZK/EI7C/LN"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "-" Then
Opties_Motor = "/AZZK"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "-" Then
Opties_Motor = "/AZZK/EI71"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "-" Then
Opties_Motor = "/AZZK/EI72"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "-" Then
Opties_Motor = "/AZZK/EI76"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "-" Then
Opties_Motor = "/AZZK/EI7C"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/AZZK/LN"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/AZZK/EI71/LN"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/AZZK/EI72/LN"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/AZZK/EI76/LN"
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Opties_Motor = "/AZZK/EI7C/LN"
'Opties_Motor DRS 71S 4 "Rem_Motor" en zonder "Handremlichter"
If Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "-" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "-" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "-" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "-" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "-" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Ja" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "-" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "-" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "-" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "-" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "-" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "-" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "1" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "2" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "6" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
ElseIf Movimot = "Nee" And Type_Motor = "DRS71S4 BE05" And Connectie_Motor = "AZZK" And Encoder = "24" And Ventilatie = "Geluidgereduceerde ventilatorkap" Then
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
I found out that there was an error in the message at the top. (I forgot to end the message with double quotation marks, and to put an End If below the code for the message). I still find it weird that it gave the error "The unit name "Light Blue M2 FG AM" is not valid in Inventor."
