weird behavior with attempting to use document
-2147467259 (80004005)
Method 'Value' of object 'property' failed
I get this error message sometimes when I run a macro I created. This macro is started by an iLogic rule at file creation (through the drawing template) and on the first drawing I create each time I open inventor it works fine. Then I get the error every time I try to create a new document. Except it works fine after the first time, regardless of whether I manually run the rule or run the macro directly from a button. I have no clue what is going on with it and why it is happening.
Here is the rule that runs at startup:
'iLogicForm.Show("Title block")
InventorVb.RunMacro("ApplicationProject", "Module1", "EditProperties")
Here is the macro that calls the form:
Sub EditProperties()
On Error GoTo 2
2:
Do While ThisApplication.ActiveDocument.NeedsMigrating
Loop
Titleblockfrm.Tardigrade
End Sub
Here is the code for the form:
Option Explicit
Private Title1 As Property
Private Title2 As Property
Private Title3 As Property
Private Material As Property
Private Finish As Property
Private Createdby As Property
Private Checkedby As Property
Private Drawingnumber As Property
Private Partnumber As Property
Private Scalel As Property
Private Scaler As Property
Dim m_DrawDoc As DrawingDocument
Private buffer As Property
Private errors As Integer
Dim oCustomPropSet As PropertySet
Private Sub CancelButton_Click()
hide
End Sub
Private Sub ApplyButton_Click()
    'On Error Resume Next
    If Me.Createdbox.Text <> Createdby.Value Then
        Createdby.Value = Me.Createdbox.Text
        'MsgBox ("createdby")
        If Newdrawingbox.Value Then
            Set buffer = oCustomPropSet.Item("Drawn Date")
            buffer.Value = DateTime.Now
    If (Not Checkedbox.Text = "") And (Not Checkedbox.Text = Checkedby.Value) Then
    If Me.Checkedbox.Text <> Checkedby.Value Then
        Checkedby.Value = Me.Checkedbox.Text
        'MsgBox ("checkedby")
    If Me.Title1box.Text <> Title1.Value Then
        Title1.Value = Me.Title1box.Text
    If Me.Title2box.Text <> Title2.Value Then
        Title2.Value = Me.Title2box.Text
    If Me.Title3box.Text <> Title3.Value Then
        Title3.Value = Me.Title3box.Text
    If Me.DrawingNumberBox.Text <> Drawingnumber.Value Then
        Drawingnumber.Value = Me.DrawingNumberBox.Text
    If Me.Partnumberbox.Text <> Partnumber.Value Then
        Partnumber.Value = Me.Partnumberbox.Text
    If Me.Materialbox.Text <> Material.Value Then
        Material.Value = Me.Materialbox.Text
    If Me.Finishbox.Text <> Finish.Value Then
        Finish.Value = Me.Finishbox.Text
    If Me.lspin.Value <> Scalel.Value Then
        Scalel.Value = lspin.Value
    If Me.Rspin.Value <> Scaler.Value Then
        Scaler.Value = Rspin.Value
    ThisApplication.ActiveDocument.Update
End Sub
Private Sub OkayButton_Click()
ApplyButton_Click
CancelButton_Click
End Sub
Private Sub Lscale_Change()
On Error GoTo l
lspin.Value = CLng(Lscale.Value)
l:
If Not Rscale.Value = "" Then
Lscale.Value = lspin.Value
End Sub
Private Sub Rscale_Change()
On Error GoTo r
Rspin.Value = CLng(Rscale.Value)
r:
Rscale.Value = Rspin.Value
End Sub
Private Sub Rspin_Change()
End Sub
Private Sub Lspin_Change()
End Sub
Sub UserForm_Initialize()
On Error GoTo 0
While ThisApplication.ActiveDocument Is Nothing
Wend
Set m_DrawDoc = ThisApplication.ActiveDocument
errors = 0
Set oCustomPropSet = m_DrawDoc.PropertySets.Item("Inventor User Defined Properties")
    Set Title1 = oCustomPropSet.Item("Title 1")
    If Err Then
        ' The property doesn't exist, so create it.
        Call oCustomPropSet.Add("", "Title 1")
        errors = errors + 1
        Call MsgBox("error")
        Err.Clear
    Me.Title1box.Text = Title1.Value
    If Err Then
    Set Title2 = oCustomPropSet.Item("Title 2")
    If Err Then
        Call oCustomPropSet.Add("", "Title 2")
        errors = errors + 1
        Err.Clear
    Me.Title2box.Text = Title2.Value
    Set Title3 = oCustomPropSet.Item("Title 3")
    If Err Then
        Call oCustomPropSet.Add("", "Title 3")
        errors = errors + 1
        Err.Clear
    Me.Title3box.Text = Title3.Value
    Set Checkedby = oCustomPropSet.Item("Checked By")
    If Err Then
        Call oCustomPropSet.Add("", "Checked By")
        errors = errors + 1
        Err.Clear
    Me.Checkedbox.Text = Checkedby.Value
    Set Createdby = oCustomPropSet.Item("Drawn By")
    If Err Then
        Call oCustomPropSet.Add("", "Drawn By")
        errors = errors + 1
        Err.Clear
    Me.Createdbox.Text = Createdby.Value
    Set Drawingnumber = oCustomPropSet.Item("Drawing Number")
    If Err Then
        Call oCustomPropSet.Add("", "Drawing Number")
        errors = errors + 1
        Err.Clear
    Me.DrawingNumberBox.Text = Drawingnumber.Value
    Set Material = oCustomPropSet.Item("Material")
    If Err Then
        Call oCustomPropSet.Add("", "Material")
        errors = errors + 1
        Err.Clear
    Me.Materialbox.Text = Material.Value
    Set Finish = oCustomPropSet.Item("Finish")
    If Err Then
        Call oCustomPropSet.Add("", "Finish")
        errors = errors + 1
        Err.Clear
    Me.Finishbox.Text = Finish.Value
    Set Partnumber = oCustomPropSet.Item("Part Number")
    If Err Then
        Call oCustomPropSet.Add("", "Part Number")
        errors = errors + 1
        Err.Clear
    Me.Partnumberbox.Text = Partnumber.Value
    If Err Then
        errors = errors + 1
        Err.Clear
    Set Scalel = oCustomPropSet.Item("Lscale")
    If Err Then
        Call oCustomPropSet.Add(1, "Lscale")
        errors = errors + 1
        Err.Clear
    Me.Lscale.Text = Scalel.Value
    Me.lspin.Value = Scalel.Value
    Set Scaler = oCustomPropSet.Item("Rscale")
    If Err Then
        Call oCustomPropSet.Add(1, "Rscale")
        errors = errors + 1
        Err.Clear
    Me.Rscale.Text = Scaler.Value
    Me.Rspin.Value = Scaler.Value
    If Err Then
        Call oCustomPropSet.Add(DateSerial(0, 0, 0), "Drawn Date")
        errors = errors + 1
        Err.Clear
    If buffer.Expression = "" Then
        Newdrawingbox.Value = True
    Else
        Newdrawingbox.Value = False
    Set buffer = oCustomPropSet.Item("Checked Date")
    If Err Then
        Call oCustomPropSet.Add(DateSerial(0, 0, 0), "Checked Date")
        errors = errors + 1
        Err.Clear
    On Error GoTo 0
'Me.Show
End Sub
Sub Tardigrade()
Show
End Sub
Also, yes, I know this a horribly document program. Sorry. Thanks to anyone who wants to help.
Nevermind, cam up with a cheap workaround
xiaodong_liang
Autodesk Support
Autodesk Support
Hi hc1245,
It will be appreciated if you could share some hints how your solved the problem:-) That may be helpful for others. Thanks!
Well, I actually decided to go back to using prompted entries, since I only needed one field (drawing number) shared between sheets. I used the normal prompted entries, and then drawing number is done through an iLogic form. As I said, pretty cheap, but it works.
