Want to replace i logic rule via vba
k14348
Message 1 of 8
k14348
  I have one assembly with ilogic rule MKA_Rule0. Now i want to edit that ilogic rule by using vba code. Rule details attached. Can anybody help?
-Karthikeyan M
Accepted solutions (3)
Replies (7)
Message 2 of 8
dean.morrison
Put the New rule text into a .txt file, and change the reference (Ruletext = ) in the code below.
VBA code below will replace the text in your rule MKA_Rule0 with the text in the .txt file you create.
Hope this helps.
Dean.
Sub Change_MKA_Rule()
Dim iLogicAuto As Object
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
Dim doc As Document
Set doc = ThisApplication.ActiveEditDocument
Dim RuleName As String
Dim ruleText As String
Dim Rule As Object
RuleName = "MKA_Rule0"
Set Rule = iLogicAuto.GetRule(doc, RuleName)
ruleText = ReadAllText("C:\TestRule.txt")
Rule.Text = ruleText
End Sub
Message 3 of 8
k14348
Compile error
 Sub or function not defined.
Code is not working
Dim doc As Document
Dim Rule As Object
ruleText = ReadAllText("C:\Users\mukarthikeyan\Desktop\MKA_Rule.txt")
End Sub
Message 4 of 8
You have missed out the function in you code to get the addin. Try this code which might be helpful.
Public Sub RuniLogic()
  Dim oDoc As Document
  Set oDoc = ThisApplication.ActiveDocument
  If oDoc Is Nothing Then
    MsgBox "Missing Inventor Document"
    Exit Sub
  Dim oRule As Object
Set oRule = iLogicAuto.getrule(oDoc, "MKA_Rule0")
oRule.Text = "iproperties.value(""Custom"", ""Air_wieght"")=Ceil((iproperties.mass+(21.156*5))*1.03)"
Beep
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Dim addIns As ApplicationAddIns
Set addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
Message 5 of 8
Here is another code in which you can edit your ilogic code from the text file.
'********Memeory allocated**************
          Exit Sub
    Dim oText As String, oFileName As String, oTextLine As String
        oFileName = "E:\test.txt" 'Add your ilogic code in this text file
        Open oFileName For Input As #1
        Do Until EOF(1)
            Line Input #1, oTextLine
            oText = "" & oTextLine
        Loop
        Close #1
    Dim oRule As Object
        oRule.Text = oText
'Release all the memory allocated to free the memory
        Set oDoc = Nothing
        Set iLogicAuto = Nothing
        Set oRule = Nothing
        Set addIn = Nothing
        Set addIns = Nothing
        Set GetiLogicAddin = Nothing
End Sub
        addIn.Activate
        Exit Function
NotFound:
End Function
Message 6 of 8
k14348
Error
Message 7 of 8
Please comment out these lines it will resolve the issue
        'Set addIn = Nothing
        'Set addIns = Nothing
        'Set GetiLogicAddin = Nothing
 I forget to do that.
Message 8 of 8
dean.morrison
Sorry i did forget about the function.
here it is.
' Get addin collection & addin variables
Dim customAddIn As ApplicationAddIn
For Each addIn In addIns
If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
Set customAddIn = addIn
Exit For
Next
If (customAddIn Is Nothing) Then Exit Function
customAddIn.Activate
Set GetiLogicAddin = customAddIn.Automation
End Function
Hopefully this resolves your issue. I did test it, but forgot to paste the function as well.
Dean.
