Want to combine ilogic programs
k14348
k14348
   I have 3 ilogic programs. Now i want to make this as a single ilogic program.Can anybody help to solve this issue?
Sub Main()
Dim drawingDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
For Each sheetX As Sheet In drawingDoc.Sheets
Dim titleBlockX As TitleBlock = sheetX.TitleBlock
If (titleBlockX Is Nothing) Then Continue For
Dim ClientDocTypeTextBox As TextBox = GetClientDocTypeTextBox(titleBlockX.Definition)
ClientDocTypeString = "DE"
titleBlockX.SetPromptResultText(ClientDocTypeTextBox, ClientDocTypeString)
Next
End Sub
Function GetClientDocTypeTextBox(ByVal titleDef As TitleBlockDefinition) As TextBox
For Each defText As TextBox In titleDef.Sketch.TextBoxes
If (defText.Text = "<Client Doc Type>" Or defText.Text = "Client Doc Type") Then
Return defText
Next
Return Nothing
End Function
Sub Main()
Dim ClientDisciplineTextBox As TextBox = GetClientDisciplineTextBox(titleBlockX.Definition)
ClientDisciplineString = "DE"
titleBlockX.SetPromptResultText(ClientDisciplineTextBox, ClientDisciplineString)
Next
End Sub
Function GetClientDisciplineTextBox(ByVal titleDef As TitleBlockDefinition) As TextBox
If (defText.Text = "<Client Discipline>" Or defText.Text = "Client Discipline") Then
Return defText
Next
Return Nothing
End Function
Sub Main()
Dim PhaseTextBox As TextBox = GetPhaseTextBox(titleBlockX.Definition)
PhaseString = "DE"
titleBlockX.SetPromptResultText(PhaseTextBox, PhaseString)
Next
End Sub
Function GetPhaseTextBox(ByVal titleDef As TitleBlockDefinition) As TextBox
If (defText.Text = "<Phase>" Or defText.Text = "Phase") Then
Return defText
Next
Return Nothing
End Function
Hi Kathik,
You Can call each program at the end of the program so that it will run as single program.
Modified snippet code
Sub Main()
Next
call Main1 '<---Modified Line 1
End Sub
Return defText
Next
Return Nothing
End Function
Sub Main1()
Next
Call Main2 '<---Modified Line 2
End Sub
Return defText
Next
Return Nothing
End Function
Sub Main2()
PhaseString = "DE"
Next
End Sub
Return defText
Next
Return Nothing
End Function
k14348
Its working. Thnx
-karthikeyan M
