VolumeOverridden bug?
nmunro
nmunro
This worked in 2009 but does not with the 2010 interop (tried with both IV 2010 and 2011).
Any part file either open in own window, or activated in the context of an assembly.
Edit the part properties and override the part volume.
Run this macro.
Public Sub VolOverride()
  Dim partDoc As PartDocument
  Set partDoc = ThisApplication.ActiveEditObject
  Dim mp As MassProperties
  Set mp = partDoc.ComponentDefinition.MassProperties
  mp.VolumeOverridden = False
End Sub
The assignment fails without error and the VolumeOverridden property value remains True.  (as if it were being treated as an assembly with one of  the include weld and occurrences properties set to true).
https://c3mcad.com
sanjay.ramaswamy
Neil,
It seems to me that the UI is behaving the same. Clearing the overridden volume field and hitting 'apply' seems to restore the value. But if you close and reopen the iProperties dialog, the volume is back to the overridden value. Let me know if you see the same, and I can file this in our system.
nmunro
Hi Sanjay,
I am seeing the same. Looks to be a deeper problem than just the API.
Neil
https://c3mcad.com
sanjay.ramaswamy
Filed as 1339032 in our system. Thanks for reporting this issue.
