Visual Studio Versions
meck
meck
Hi All,
Is there a limit to which version of visual studio I can use with Inventor?
For instance right now we are using Inventor 2013 but we are planning on upgrading soon. That said IT tell me that we only have license for visual studio 2010. So if we upgrade to newest version of Inventor will I have any issues using VS 2010? If so what is the newest version of Inventor I'll be able to upgrade to?
Conversely if we upgrade to the latest version of VS will it work with older versions of Inventor?
Personally I have not experienced any issues with any release of either software, but IT is insisting that I double check to make sure.
Thanks in advance!
Mike
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @meck,
Inventor 2015 is built with Visual studio 2012 and target .Net 4.5. Inventor 2015 and higher versions supports Visual studio 2012 and higher versions.
For more details, refer the following blog link.
http://adndevblog.typepad.com/manufacturing/2015/02/which-net-framework-version-is-inventor-using.ht...
Based on .Net framework, Visual Studio version can be decided.
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
I'm using VS 2017 Community with Inventor 2017 and 2018.
If you use addin Wizard, you may need to use VS 2015 or below.  Since the installer won't recognize VS 2017.
Otherwise it doesn't matter which version of VS you're using.
I've just recompiled all my addins to .net 4.7.1.
andrew_canfield
Which versions of Visual Studio work with Inventor 2018?
(would VS2019?)
Regards
Andrew
chandra.shekar.g
Autodesk Support
Autodesk Support
@andrew_canfield,
Actually, Inventor 2020 is built with Visual studio 2017. Having said that the addin created by Visual studio 2019 may be supported for Inventor 2018 - 2020. But, there is no guarantee that Visual Studio 2019 should be supported for Inventor 2018 - 2020.
In general, a newer Visual Studio always supports lower .Net Framework and Platform Toolset. If Visual Studio 2019 supports the lower .Net Frameworks and Platform Toolset. I think, it should be fine to use it for Inventor 2018-2020.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
