visibility solid body with af combination of 4 custom properties.
gma
Message 1 of 11
gma
I have a part, with a lot of derived components(Solid bodies).
I use 4 different custom properties, and I want to use the 4 different custom properties to visibility  one solid bodies. Each 4 custom properties can be different.
1. Custom properties: S18 (S10, S11)
2. Custom properties: 6 (9, 18)
3 Custom properties: RD (SQ)
4. Custom properties: 20 (25)
Is it possible to visibility one solid body with a rule?
So when i have a kind of a kombination with the 4 custom properties, then the rule will finde the solid body, and set it to visibility.
Thank you in advance.
Best regards
Gøsta
Replies (10)
Message 2 of 11
FINET_Laurent
Morning,
What are you refering to when talking about custom properties ? iProperties ? Parameters?
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 11
FINET_Laurent
I did this one quickly, maybe this helps. Are you familiar with iLogic ?
Sub Main
Param1 = S18
Param2 = 6
Param3 = RD
Param4 = 20
Dim sParameters As String = Param1 & Param2 & Param3 & Param4 'merge all parameters one next to the other
Select Case sParameters 'create a case for all combinaisons
	Case S186RD20
		Call SupressAllFeatures 'see function at the bottom of the code
		Feature.IsActive("featurename") = True ' the one body you want to be visible in that case
	Case S106RD20
Case S116RD20 Call SupressAllFeatures Feature.IsActive("featurename") = True End Select End Sub Function SupressAllFeatures 'function that supress all bodies in the part Dim oDoc As PartDocument oDoc = ThisApplication.ActiveDocument Dim oFeature As PartFeature For Each oFeature In oDoc.ComponentDefinition.Features oFeature.Suppressed = True Next End Function
FINET L.
Message 4 of 11
JhoelForshav
@gma
I don't know if I understand correctly but the way I interpret this question is that you want to control the visibility property of some solid bodies with custom iProperty values?
I made an example ipt for you but I don't know which version of inventor you're running. Attached ipt is inventor 2020.
In the ipt there are 4 solid bodies named Solid1, Solid2 Solid3, Solid4.
There are also 4 custom iproperties of type "Yes or No" named SOLID1, SOLID2, SOLID3, SOLID4.
I've set this rule to trigger on iProperty change:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSurfBods As SurfaceBodies = oDoc.ComponentDefinition.SurfaceBodies
oSurfBods.OfType(Of SurfaceBody).Where(Function(b) b.Name = "Solid1")(0).Visible = If (iProperties.Value("Custom", "SOLID1") = True, True, False)
oSurfBods.OfType(Of SurfaceBody).Where(Function(b) b.Name = "Solid2")(0).Visible = If (iProperties.Value("Custom", "SOLID2") = True, True, False)
oSurfBods.OfType(Of SurfaceBody).Where(Function(b) b.Name = "Solid3")(0).Visible = If (iProperties.Value("Custom", "SOLID3") = True, True, False)
oSurfBods.OfType(Of SurfaceBody).Where(Function(b) b.Name = "Solid4")(0).Visible = If(iProperties.Value("Custom", "SOLID4") = True, True, False)
 The values of these properties will therefore control the visibility of the solids. Is this what you're trying to accomplish? 🙂
Message 5 of 11
gma
Iproperties
Message 6 of 11
FINET_Laurent
Maybe this ?
Sub Main
Dim Param1 As String = iProperties.Value("Custom", "PropertyName") 'Change the property name to the desired one
Dim Param2 As String = iProperties.Value("Custom", "PropertyName")
Dim Param3 As String = iProperties.Value("Custom", "PropertyName")
Dim Param4 As String = iProperties.Value("Custom", "PropertyName")
Select Case sParameters 'create a case for all combinaisons, like so
	Case S186RD20
	Case S106RD20
	Case S116RD20
	'Case xxx...
End Select
End Sub
Next
End Function
Message 7 of 11
FINET_Laurent
Coding the 15 cases is a pain tho.. ^^'
Message 8 of 11
gma
Nothings happen....
No bodys are visibilitied
Message 9 of 11
FINET_Laurent
Can you share the code ?
FINET L.
Message 10 of 11
gma
Sub Main
Dim Param1 As String = iProperties.Value("Custom", "Serie") 'Change the property name to the desired one
Dim Param2 As String = iProperties.Value("Custom", "Z")
Dim Param3 As String = iProperties.Value("Custom", "Hul")
Dim Param4 As String = iProperties.Value("Custom", "HulDia")
	Case S18Z6ZRD20
		Feature.IsActive("Solid1::S18Z6ZRD20") = True ' the one body you want to be visible in that case
	Case S18Z6ZRD25
		Feature.IsActive("Solid1::S18Z6ZRD25") = True
'	Case S116RD20
'		Call SupressAllFeatures
'		Feature.IsActive("featurename") = True
	'Case xxx...
End Select
End Sub
Message 11 of 11
gma
