Virtual Components - 0 qty patterns
NachoShaw
Advisor Advisor
NachoShaw
Hey
I am working with some asembly level iLogic and Virtual components. My objective is to add the VC to a pattern so that based on a parameter qty value, i can update the pattern to quantify the amount of VC parts. This works great and very easy on the basis that a pattern has a value of 1 or more. If the pattern value becomes 0, i get an error even if my iLogic is set up to suppress the pattern on 0 values.
Any better / other way to manage VC qty's based on a parameter value that doesnt require a tone of overhead code?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
A.Acheson
 My two cents:
In 2020 testing manually with no code, a pattern containing a VC cannot be suppressed. It doesn't do anything, so likely you will need to delete the pattern and VC or alternatively you could do away with the pattern and just overwrite the BOM
ThisBOM.OverrideQuantity("Model Data", "VC", "300")
Regards
Alan
NachoShaw
Hey
Yeah that works but iLogic doesn't update the value when the parameter is changed. The base model model changes, the linked parameter in the assembly changes but the bom doesn't update with iLogic...
I really don't like ilogic
Nacho
A.Acheson
Have you a quick sample of the update issues? You can always switch out the ilogic snippet for the api version if therre is an issue with that. Sequencing can always be an issue for sure. But  z
Regards
Alan
NachoShaw
prob later mate. Think I'll just change it l to a vb.net class and run it from there, always works in vb.net 🙂
Nacho
el_jefe_de_steak
In order to make an iLogic rule run automatically, you have to call out the parameter that you want it to respond to.
Whenever a parameter name shows up in BLUE text in the iLogic rule editor, the iLogic rule will run if that parameter value changes.
