ViewLabels and stuff
mgrenier2
mgrenier2
I need to add prefixes to views through the style manager for an iLogic rule to work properly
But this is causing some unwanted side effects  and I could not find a way to turn it off
And here's the rule in question :
' Librarie de code iLogic/VBA Métal Marquis
' Auteur: Mathieu Grenier
' Nom: Vues dépliées
' Catégorie: Règles de mises en plans
' Date: 2025-06-04
' Description: Place des vues dépliées pour chaque pièce de tolerie présente sur la feuille de dessin active
' Version: 1.0
' En développement: Oui
' Notes:
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim sheet As Sheet = doc.ActiveSheet
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Add("SheetMetalFoldedModel", False)
For Each view As DrawingView In sheet.DrawingViews
    Dim viewName As String = view.Name.ToUpper()
    ' Ignorer les vues projetées ou générées automatiquement
    If viewName.StartsWith("PROJ") _
    Or viewName.StartsWith("AUX") _
    Or viewName.StartsWith("COUPE") _
    Or viewName.StartsWith("DRAFT") _
	Or viewName.StartsWith("DETAIL") _
    Or viewName.StartsWith("VIEW") Then
        Continue For
    Try
        Dim refDoc As PartDocument = Nothing
        Try
            refDoc = View.ReferencedDocumentDescriptor.ReferencedDocument
        Catch
            Continue For
        End Try
        If Not refDoc Is Nothing Then
            Dim def As SheetMetalComponentDefinition = Nothing
            Try
                def = refDoc.ComponentDefinition
            Catch
                Continue For
            End Try
            If def.HasFlatPattern Then
                If def.FlatPattern Is Nothing Then
                    def.Unfold()
                    def.FlatPattern.ExitEdit()
                Dim pt As Point2d = ThisApplication.TransientGeometry.CreatePoint2d( _
                    View.Center.X, View.Center.Y + 10)
                Dim oFlatView As DrawingView = sheet.DrawingViews.AddBaseView( _
                    refDoc, _
                    pt, _
                    View.Scale, _
                    ViewOrientationTypeEnum.kFrontViewOrientation, _
                    DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, _
                    , , oOptions)
					oFlatView.ShowLabel = False
                	oFlatView.Name = "FLAT_" & view.Name
    Catch
        Continue For
    End Try
Next
So like, the rule need to ignore every view on the active drawing sheet that isn't a base view.
How can I achieve this, or just hide the view prefix from the section view lines and the detail bubble?
mgrenier2
Never mind, I figured it out
C_Haines_ENG
You should include your solution, and mark it as the solution to close out the thread.
mgrenier2
Is it really a solution if I just turned it off ? 😂
C_Haines_ENG
😂I guess not, but you could just check what type of view you were on instead of grabbing a prefix.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
For Each oView As DrawingView In oSheet.DrawingViews
	MsgBox(oView.ViewType.ToString)
Next
