ViewCube rotation through API
I'm trying to access the ViewCube trough the API. Through the CommandManager.Controldefinitions i'm able to execute the commands for ViewCube: Front/Right/Top using either AppFrontViewCmd/AppRightViewCmd/AppTopViewCmd
commandManager.ControlDefinitions["AppFrontViewCmd"].Execute();
The commands for rotating to Left/Bottom/Back is not present in the same way as the commands above - and it seems a bit strange that only 3 sides of the ViewCube is availabe. How can I fix this, so that i'm able to rotate to any side of the ViewCube?
Curtis_Waguespack
Hi erik.martinsson,
Here is a quick iLogic example that I had on hand.
I hope this helps.
Curtis
Dim oCamera As Camera
oCamera = ThisApplication.ActiveView.Camera
oCamera.ViewOrientationType = 10756 'Back View
oCamera.Apply
'list of view enums: ' kTopViewOrientation = 10754 ' kRightViewOrientation = 10755 ' kBackViewOrientation = 10756 ' kBottomViewOrientation = 10757 ' kLeftViewOrientation = 10758 ' kIsoTopRightViewOrientation = 10759 ' kIsoTopLeftViewOrientation = 10760 ' kIsoBottomRightViewOrientation = 10761 ' kIsoBottomLeftViewOrientation = 10762 ' kFrontViewOrientation = 10764
Well that certainly looks like something that would work. Will try it out first thing monday morning - Thanks alot 😃
