View Rep driven rule
Formsprag
Formsprag
I have a drawing with 64 View Reps, How do I use iLogic to run a rule based on the View Rep selected?
J-Camper
Here is how you can get the current view rep and loop through all view reps.  Not sure what else you're trying to do.
Dim RepManager As RepresentationsManager = ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager
Dim viewReps As DesignViewRepresentations = RepManager.DesignViewRepresentations
Dim currentView As DesignViewRepresentation = RepManager.ActiveDesignViewRepresentation
'Loop through all
Dim viewFrame As DesignViewRepresentation
For Each viewFrame In viewReps
	'Test for what you are looking for
	If UCase(Left(viewFrame.Name, 5)) = "FRAME"
		viewFrame.Activate
		'Do what you want
	Else
		'Go to next
Next
'Return to Master View as active: viewReps.Item(1).Activate
Just redefine RepManager for documents in question
