View not precise ...
Hi!
Is there a way to avoid the dialog 'Some of the views on the following
sheet(s) ar not precise' or to tell when Inventor has finished generating
the model or drawing? Is there an event or a property that can tell me that?
Thanks in advance
/Per
Sounds like your trying to do some batch operations.......That event is not available yet. Mike
It it as avaible in 5.3 but not in 5.
Sheet.Status
you will have to loop until the sheet status is
equal to kUpToDateDrawingSheet
 Mike Martin
Sounds
yet. Mike
The sample code in the online help for the Status
property is incorrect.  The code below should work.
    If oSheet.Status And
kProcessingPreciseDisplayDrawingSheet = kProcessingPreciseDisplayDrawingSheet
Then
        MsgBox
"Sheet is still processing."
    Else
        MsgBox
"Sheet is up to date."
-Brian
5.
Sheet.Status
 Mike Martin
Sounds
available yet. Mike
