VBA run External Rule from Existing Addin
j.romo
j.romo
For  my Purchased parts downloaded from the web I made an Add-in that changes the part to purchased and adds some custom Iprops, now that Im working with MS Access I want to add that part to a Parts list from the project from a button in the Add-in but Cant figuer out how to call a external rule to run frm the click of the button.
here is the code in the Default.ivb-COMPRAS (code)
Private Sub CommandButton1_Click()
Dim invDoc As Document
Set invDoc = ThisApplication.ActiveDocument
' Get the user defined (custom) property set.
Dim invCustomPropertySet As PropertySet
Set invCustomPropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
' Declare some variables that will contain the various values.
Dim strProv As String
Dim STRTEL As String
Dim strEmail As String
Dim strTE As String
Dim strWBL As String
' Set values for the variables.
strProv = "Some sample text."
STRTEL = TextBox1.Value
strEmail = "Some sample text."
strTE = "Some sample text."
strWBL = "Some sample text."
' Create the properties.
Set invProperty = invCustomPropertySet.Add(strProv, "PROVEEDOR")
Set invProperty = invCustomPropertySet.Add(STRTEL, "TELEFONO")
Set invProperty = invCustomPropertySet.Add(strEmail, "E-MAIL")
Set invProperty = invCustomPropertySet.Add(strTE, "TIEMPO DE ENTREGA")
Set invProperty = invCustomPropertySet.Add(strWBL, "WEB")
End Sub
Private Sub CommandButton2_Click()
' Get the active document.
Dim doc As Document
Set doc = ThisApplication.ActiveDocument
' Get the custom property set.
Dim customPropSet As PropertySet
Set customPropSet = doc.PropertySets.Item( _
' Get the property named "TELEFONO".
Dim customProp1 As Property
Dim customProp2 As Property
Dim customProp3 As Property
Dim customProp4 As Property
Dim customProp5 As Property
Set customProp1 = customPropSet.Item("TELEFONO")
Set customProp2 = customPropSet.Item("PROVEEDOR")
Set customProp3 = customPropSet.Item("E-MAIL")
Set customProp4 = customPropSet.Item("TIEMPO DE ENTREGA")
Set customProp5 = customPropSet.Item("WEB")
' Set the value of the property.
customProp1.Value = TextBox1.Value
customProp2.Value = TextBox2.Value
customProp3.Value = TextBox3.Value
customProp4.Value = TextBox4.Value
customProp5.Value = TextBox5.Value
End Sub
Private Sub CommandButton3_Click()
Dim doc As Document
doc.ComponentDefinition.BOMStructure = 51973
End Sub
Private Sub database_Click()
End Sub
clutsa
Call mySubName
'or
Call myModuleName.mySubName
I'm missing something.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
j.romo
I found This rule but i cant make it to work as I want
The code is from Owner2229
I made a new Module
Public Sub ComprasRule()
    'ilogic rule name:
     RuniLogic ("X:\RECURSOS INVENTOR\Design Data\iLogic\EXTERNAL RULES\ComprasDb.iLogicVb")
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
    Dim iLogicAuto As Object
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    If oDoc Is Nothing Then
        MsgBox "Missing Inventor Document"
        Exit Sub
    Set iLogicAuto = GetiLogicAddin(ThisApplication)
    If (iLogicAuto Is Nothing) Then Exit Sub
    iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Public Function GetiLogicAddin(oApplication As Inventor.Application) As Object
    Dim addIn As ApplicationAddIn
    On Error GoTo NotFound
    Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
    If (addIn Is Nothing) Then Exit Function
    addIn.Activate
    Set GetiLogicAddin = addIn.Automation
    Exit Function
NotFound:
End Function
and in the button code
 Call ComprasRules.ComprasRule
End Sub
clutsa
I can't really test this but try dropping the full file path down to just the external rule name
    'ilogic rule name:
     RuniLogic ("ComprasDb")
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@j.room,
I found that code in below forum post is working fine.
https://forums.autodesk.com/t5/inventor-customization/run-ilogic-external-rule-with-inventor-vba/td-...
Public Sub RunRule()
    RuniLogic ("C:\Users\t_gc\Desktop\Sample.iLogicVb")
End Sub
        Exit Sub
End Sub
    addIn.Activate
    Exit Function
NotFound:
End Function
Why below code is needed? Is there any class "ComprasRules"?
End Sub
Function can be called directly using below code.
 Call ComprasRule
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
clutsa
Are you sure the error happens in the code you have posted and not in
 Maybe try making a simple external rule that just posts back a message box that says "Done" and see if that gives you any trouble
j.romo
Thanks A lot Chandra and Clutsa,
The action will be a Button in the User Form
I inserted the code as follows
End Sub
Exit Sub
End Sub
addIn.Activate
Exit Function
NotFound:
End Function
Dim doc As Document
End Sub
Private Sub CommandButton4_Click()
Call RunRule
'MsgBox "Missing Inventor Document"
End Sub
And It worked directly in the User Form
Thanks a lot guys
