Curtis,
I have the code stated below, I was hoping you could help with a few things:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 24470 StartFragment: 314 EndFragment: 24438 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main
iLogicVb.RunRule("CustOn")
'query user
MessageBox.Show("Would you like to print to the current Project File?: ", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'set condition based on answer
If question = vbYes Then
oFileName = ThisDoc.FileName(False) 'without extension
oRevNum = iProperties.Value("Project", "Revision Number")
Else
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
'Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
'oOptions.Value("Launch_Viewer") = launchviewer
oOptions.Value("All_Color_AS_Black") = 1
'oOptions.Value("Sheet_Range") = ThisApplication.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = Left(ThisDoc.Path, InStrRev(oPath, "\")) & "PDF"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'Set the PDF target file name
Dim fname As String
fname = oFolder & "\" & oFileName & " Rev" & oRevNum & "-CUST.pdf"
oDataMedium.FileName = fname
'Publish document.
If System.IO.Directory.Exists(fname) Then
System.IO.File.Delete(fname)
MessageBox.Show("Earlier PDF deleted! ", "Inventor")
PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
MessageBox.Show("Print Created in default Projects - " & fname, "Inventor")
End Sub
First I was hoping I could have the project name added after the question in the project file. Also I was going to try and set up a browser the would pop up if you were to hit no where you can manually map the file where you'd like it to save?
Any ideas? I am pretty new to all of this and its getting a little too complex for my experience.
