VBA Rectangular Pattern regardless from the Workaxis
Dear big programming world!
I tried a RectangularPattern via VBA. I got it going in an assembly. But it only works with the work axes. Is there a way to let the pattern run along a unit vector or the like? How do I create a Rectangular Pattern in a Part and in an Assembly? How can I set a direction regardless of the work axes? Please help me. Thank you
' Set a reference to the active assembly document
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
' Set a reference to the AssemblyComponentDefinition
Dim oDef As AssemblyComponentDefinition
Set oDef = oDoc.ComponentDefinition
' Get the x\-axis of the assembly
Dim oXAxis As WorkAxis
Set oXAxis = oDef.WorkAxes.Item(1)
' Get the y\-axis of the assembly
Dim oYAxis As WorkAxis
Set oYAxis = oDef.WorkAxes.Item(2)
Dim oParentOccs As ObjectCollection
Set oParentOccs = ThisApplication.TransientObjects.CreateObjectCollection
oParentOccs.Add oDef.Occurrences.Item(1)
' Create a rectangular pattern of components\:
' 4 columns in the x\-direction with an offset of 5 in
' 3 rows in the y\-direction with an offset of 4 in
Dim oRectOccPattern As RectangularOccurrencePattern
Set oRectOccPattern = oDef.OccurrencePatterns.AddRectangularPattern( _
oParentOccs, oXAxis, True, "5 in", 4, oYAxis, True, "4 in", 3)
End Sub
JaneFan
Hey @Anonymous ,
I guess you are saying two things:
In assembly: it is occurrence pattern: OccurrencePatterns.AddRectangularPattern()
In AddRectangularPattern method, we can provide direction which need be proxy object that defines the direction of the pattern. This must be a proxy to a linear edge or a work axis.
In part: it is rectangular pattern feature:
Features.RectangularPatternFeatures.AddByDefinition()
Features.RectangularPatternFeatures.CreateDefinition()
In CreateDefinition method, we can provide X and Y directions, which can be linear entity like a linear Edge, a WorkAxis, a WorkPlane (normal is used), a planar Face (normal is used), or a GeometryIntent
Jane Fan
Inventor/Fusion QA Engineer
Hey Jane!
Thank you for your hint. I tried it and now I can also create patterns in a part.
Only I still don't understand how to use an edge of the body instead of an axis. I think I'll explain that in more detail in another post.
This is my code:
Sub RPF()
    Dim oPCD As PartComponentDefinition
    Set oPCD = ThisApplication.ActiveDocument.ComponentDefinition
    Set oXAxis = oPCD.WorkAxes.Item(1)
    Dim oOC As ObjectCollection
    Set oOC = ThisApplication.TransientObjects.CreateObjectCollection
    Call oOC.Add(oPCD.Features.Item(1))
    Dim oRPFD As RectangularPatternFeatureDefinition
    Set oRPFD = oPCD.Features.RectangularPatternFeatures.CreateDefinition(oOC, oXAxis, True, 3, 10)
    Dim oRPF As RectangularPatternFeature
    Set oRPF = oPCD.Features.RectangularPatternFeatures.AddByDefinition(oRPFD)
End Sub
