vba Read revision number from drawing not model
CAD-e-Shack
CAD-e-Shack
I'm writing a macro that exports .idw's to .dxf's. For each new revision we save a new copy with the revision number tagged onto the part number ( Example I00-001234 revision 1 becomes I00-001234R1).
The problem comes when i try to extract the revision number from the drawing. Because the drawing updates the revision from the model, the titleblock shows the model revision. However, when I pull the revision number, the code pulls the data from the sheet iproperties rather than the model iproperties.
Is there a way to pull the model revision, or a way to pull the data from the titleblock on the drawing?
Private SaveasDXF_Click()
Dim FSO As Scripting.FileSystemObject
Dim InvDocuments, Path As Documents
Dim invDocument As Document
Dim InvDoc, oDoc As Document
Dim FilePath As String
Dim newDXF As String
Dim PopUp As String
Dim Ans As String
Dim InvRevision As Property
Dim Revision As String
Set InvDoc = ThisApplication.ActiveDocument
Set Path = ThisApplication.Documents
Set InvRevision = InvDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
'^^^ This line reads the sheet revision (which is 0) but the model revision is 1
    Set FSO = New Scripting.FileSystemObject
            FilePath = "C:\TEMP" + newDXF
            MsgBox "Revision Number: " & InvRevision.Value
            If FSO.FileExists(FilePath) = False Then
                If InvRevision.Value = Null Or 0 Then
                    Revision = ""
                Else
                    Revision = "R" + CStr(InvRevision.Value)
                    newDXF = newDXF + Revision
    ' Here I call the function to save copy as DXF
            Else
                PopUp = "Do you wish to overwrite the file" & vbNewLine & _
                newDXF & "?"
                Ans = MsgBox(PopUp, vbOKCancel, "Overwrite File?")
                    If Ans = vbOK Then
                'Delete old file
                    With New FileSystemObject
                        .DeleteFile "C:\TEMP" & newDXF
                        End With
                            Revision = ""
                        Else
      ' Here I call the code to save a copy as DXF
                    Else
End Sub
I presume that you are in a idw when you call SaveasDXF
If so you must change:
into this:
Dim InvModelDoc as Inventor.Document
Set InvModelDoc = InvDoc..ReferencedDocuments(1)
Set InvRevision = InvModelDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
This gives you the revision of the model which belongs by the iDW
CAD-e-Shack
Thanks a lot. It works perfectly now.
The .idw wasn't the open document, but I solved this by changing:
to
Set InvDoc = Path.Item(j) (and of course moving this below the point where j is defined as the correct integer.)
