VBA Project default ivb password protected
ckuester
ckuester
i wrote a little vba Programm within the drawing application of Inventor 2016.
Now i installed Inventor 2017 and copied the Default.ivb file.
Now this Programm  has some difficulties to run and i want to Change it.
Unfortunately the code ist suddenly protected by a Password!!  I never ever defined a Password ...
Is there a Chance reset the pasword?
Greetings
Christian
ekinsb
Truthfully, I wasn't even aware you could set a password for a VBA project.  It's something built-in to VBA and is not something that Inventor has added.  We don't have any special way to remove a password.  However, I did do some research online and others have run into the same problem with other applications that use VBA; primarily Excel.
Can you send me your project and I'll see if what I found will work.  I can't make any guarantees but I'll give it a shot.  You can send your project directly to me at brian.ekins at autodesk.com.
Brian Ekins
Mod the Machine blog
NachoShaw
VBA project files don't just assign themselves a password. Furthermore, you have to enter the same password twice in order to set the password. I know that some people here provide vba project files for others to use but pw protect them to protect their work? Maybe you have selected that in 'error'. I know that I wouldn't be very happy if I kindly provided a vba project file and someone went ahead and cracked it open.
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
ekinsb
Nacho, Good point.  I'll do a little due diligence before I attempt to crack the file.
Brian Ekins
