VBA Place cursor away from part window
rcolon9E4ZX
rcolon9E4ZX
Hey guys,
I have created a program to export the bill of materials to excel, one step of which opens parts and captures the thumbnails. Sometimes, when the cursor is over the part, I get a red shaded face. The hope is to re - position the cursor away from the part window.
I have found and modified a code that works great with VBA within excel. I can get and set the location of the cursor.
' Access the GetCursorPos function in user32.dll
Declare Function GetCursorPos Lib "user32" _
(lpPoint As POINTAPI) As Long
Declare Function SetCursorPos Lib "user32" _
(ByVal x As Long, ByVal y As Long) As Long
' GetCursorPos requires a variable declared as a custom data type
' that will hold two integers, one for x value and one for y value
Type POINTAPI
   X_Pos As Long
   Y_Pos As Long
End Type
Private Sub Get_Cursor_Pos()
    ' Main routine to dimension variables, retrieve cursor position,
    ' and display coordinates
    Range("A1").Value = "X"
    Range("A2").Value = "Y"
    Dim i As Integer
    i = 0
Do Until i = 10000
    ' Dimension the variable that will hold the x and y cursor positions
    Dim Hold As POINTAPI
    ' Place the cursor positions in variable Hold
    GetCursorPos Hold
    ' Display the cursor position coordinates
'      MsgBox "X Position is : " & Hold.X_Pos & Chr(10) & _
'         "Y Position is : " & Hold.Y_Pos
    Range("B1").Value = Hold.X_Pos
    Range("B2").Value = Hold.Y_Pos
    i = i + 1
Loop
End Sub
Private Sub Set_Cursor_Pos()
' Routine to set cursor position
' Looping routine that positions the cursor
   For x = 1 To 480 Step 20
      SetCursorPos x / 46.1, x / 46.1
      For y = 1 To 40000: Next
   Next x
End Sub
However, when I bring the same code into Inventor and try to run it, I get:
What must be changed so that the code may work with 64-bit Inventor 2017?
Office 2013
Windows 7 Professional 64 bit
Please let me know if any more information is required.
Any help with this would be much appreciated.
rcolon9E4ZX
I figured out my own problem. I love when the solution is a 100 times simpler than imagined.
Hold your breath...
Declare PtrSafe Function SetCursorPos Lib "user32" _
Simply adding 'PtrSafe' after Declare solves the issue and the program works in 64bit Inventor now.
Here is the code to re-position the cursor anywhere on the screen. Currently set to top left of screen. (10,10) [x,y]
    SetCursorPos 10, 10
End Sub
It would be interesting to know what the PtrSafe Attribute is doing for the declaration in a 64bit application.
Hope this helps someone else.
