VBA Named face joint error
peter.ensing
peter.ensing
Hello all!
So I'm trying to ridig joint an assembly to another item. This other item is simply picked with the commandmanager.
Inside the assembly template is a part with a named face. I want the user only need to pick the hole and it'll create the joint.
But I get an runtime error. Somebody knows whats going wrong? (the code works if I replace the named face code for just another commandmanager face pick)
Public Sub AssemblyConnect()
    ' Create a new assembly document.
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    Dim asmDef As AssemblyComponentDefinition
    Set asmDef = asmDoc.ComponentDefinition
  Dim oOcc As ComponentOccurrence
  Set oOcc = asmDoc.SelectSet(1)
Dim occsub As ComponentOccurrence
Set occsub = oOcc.SubOccurrences.Item(2)
Dim oPartDoc As PartDocument
Set oPartDoc = occsub.Definition.Document
Dim oFace2 As face
Set oFace2 = oPartDoc.AttributeManager.FindObjects(, , "Jointface")(1)
    Dim oAdoc As AssemblyDocument
    Set oAdoc = oOcc.Definition.Document
    Dim oFace1 As Edge
    Set oFace1 = ThisApplication.CommandManager.Pick(kPartEdgeCircularFilter, "select a hole")
    ' Create two intents to define the geometry for the connection.
    Dim intentOne As GeometryIntent
    Set intentOne = asmDef.CreateGeometryIntent(oFace1, PointIntentEnum.kCenterPointIntent)
    Dim intentTwo As GeometryIntent
    Set intentTwo = asmDef.CreateGeometryIntent(oFace2, PointIntentEnum.kPlanarFaceCenterPointIntent)
    ' Create a rigid connection between the two parts.
    Dim connectDef As AssemblyJointDefinition
    Set connectDef = asmDef.Joints.CreateAssemblyJointDefinition(kRigidConnectionType, intentTwo, intentOne)
    connectDef.FlipAlignmentDirection = False
    connectDef.FlipOriginDirection = False
    Dim connect As AssemblyJoint
    Set connect = asmDef.Joints.Add(connectDef)
    ' Make the connection visible.
    connect.Visible = False
End Sub
Thanks in advance and kind regards,
Peter
JhoelForshav
Hi @peter.ensing
The reason it works with pick method is because it creates geometry proxy for the picked geometry that the top level assembly can use. An assembly doesn't contain the actual geometry that is in the parts. Its basically just a structure of references. To work with the geometry in the assembly you'll have to reference it through a proxy. I copied your code and added a few lines to make a proxy for the named face:
Dim oFace2 As Face
'Create the face proxy
Dim oFace2Prox As FaceProxy
Call occsub.CreateGeometryProxy(oFace2, oFace2Prox)
Call oOcc.CreateGeometryProxy(oFace2Prox, oFace2Prox)
Dim oFace1 As Edge
'Use the proxy objext instead
Set intentTwo = asmDef.CreateGeometryIntent(oFace2Prox, PointIntentEnum.kPlanarFaceCenterPointIntent)
End Sub
peter.ensing
@JhoelForshavThis works like a charm, thanks for that!
Also thanks for the explanation why it didnt work, makes sense now...
